Finding DSOs with Questar 3.5
18 replies to this topic
#1 Tom3
Tom3
  • Loc: Scottsdale, AZ
Posted 16 July 2020 - 11:07 AM
How do people locate DSOs in a Q 3.5? They are mostly too dim to see in the finder.
Thanks for any suggestions.
#2 Xeroid
Xeroid
  • Loc: USA
Posted 16 July 2020 - 11:22 AM
How about using a Star Chart planetarium app* with both of these tools?
Wixey Digital Angle Gauge
Sighting Compass
You will be able to get approximate AZ and ALT readings of the scope to match those from the star chart  planetarium app*
Oh and also use a low power/wide angle eyepiece ?
Edit:
* Thanks to JamesMStephens for correcting my "senior moment: one can get DSO ALT & AZ or RA/DEC from planetarium app like SkySafari, Stellarium or Cartes du Ciel"
Edited by Xeroid, 16 July 2020 - 02:36 PM.
#3 Tom3
Tom3
Posted 16 July 2020 - 11:30 AM
How about using a Star Chart with both of these tools?
Sighting Compass
Good ideas! Thanks,
#4 Giorgos
Giorgos
  • Loc: Athens, Greece
Posted 16 July 2020 - 11:38 AM
a) Using the setting circles with the telescope on a wedge as an equatorial. a) Putting the tube on a goto computerized mount and let the mount find them (if you have the Questar Duplex that can be deforked easily). As already mentioned a low power "finder" eyepiece is usefull.
#5 JamesMStephens
JamesMStephens
  • Loc: Hattiesburg, Mississippi
Posted 16 July 2020 - 12:21 PM
Xeroid seems to be suggesting using the scope in Alt-Az mode.  Here's a great discussion of that using the Q's setting circles for altitude and azimuth rather than declination and right ascension, no compass or angle guage required (though they may be useful in setting up.)
https://www.cloudyni...-questar-setup/
You will need a planetarium app to get altitude and azimuth, they can't be read or even estimated from a start chart.
There are a few discussions on the forum about using the setting circles in the intended equatorial mode and skilled observers are able to locate DSOs with them.
https://www.cloudyni...us the latitude.
Edited by JamesMStephens, 16 July 2020 - 12:22 PM.
#6 Tom3
Tom3
Posted 16 July 2020 - 12:37 PM
I use my scope in equatorial mode, so I will work with the setting circles. I guess finding a bright star near the DSO, adjust RA accordingly and then find the DSO.
  • JamesMStephens likes this
#7 JamesMStephens
JamesMStephens
Posted 16 July 2020 - 12:51 PM
Tom,
I think you're describing the off-set method
"SIMPLE OFF-SET METHOD: This was written about in Sky and Telescope, Sept. 1990, p.246. It enables going from a known star, calculating in advance the correct off-set in R.A. and Dec., and then moving the scope the appropriate amount. It can be quite an effective use of setting circles, though I rarely use it."
Quoted from https://calgary.rasc.ca/scircles.htm
#8 Tom3
Tom3
Posted 16 July 2020 - 03:28 PM
Jim,
Yes, that's what I described. I might try setting RA with an app on my phone that calculates local sidereal time.
#9 Simoes Pedro
Simoes Pedro
Posted 16 July 2020 - 03:58 PM
I use a red dot finder. But finding DSO's is a pain.
#10 rcwolpert
rcwolpert
  • Loc: South Hutchinson Island, Florida
I put my Q on a Meade on a LX-85 and find anything within the light grasp of the 3.5”.
Edited by rcwolpert, 16 July 2020 - 05:30 PM.
#11 JamesMStephens
JamesMStephens
Posted 16 July 2020 - 05:21 PM
RC, Is this your back yard?
#12 rcwolpert
rcwolpert
Posted 16 July 2020 - 05:33 PM
Hi Jim,
That's actually in front of my 2nd floor condo, which looks like the condos on the other side of the lake. Everything has to be carried to this location, so it's not so easy setting up.
Bob
  • cbwerner and JamesMStephens like this
#13 Tom3
Tom3
Posted 16 July 2020 - 09:31 PM
Having a duplex adds options not available with standard Q. Very good setup.
  • rcwolpert and JamesMStephens like this
#14 JamesMStephens
JamesMStephens
Posted 16 July 2020 - 09:32 PM
Jim,
SkySafari will give you LST.
#15 JamesMStephens
JamesMStephens
Posted 16 July 2020 - 09:45 PM
Hi Jim,
Bob
I was hoping it was your patio!
#16 cbwerner
cbwerner
    Bicycle Repairman
  • Loc: Maidens, VA
Posted 16 July 2020 - 10:12 PM
Hi Jim,
Bob
#17 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 16 July 2020 - 11:21 PM
Star hopping with the finder and pattern interpretation.   See where the DSO is relative to stars you can see with a good atlas.  With the Q, the Pcket Sky Atlas or Sky Atlas 2000 work well.  Then picture how it will look flipped since the finder view does that., Example,  extend a line through those two stars by 1/2 again as long or mid way between these two or whatever.  Then pattern match from the atlas to the finder view, then flip to the eyepiece.
Same technique I use with my 10”, 11”, and other scopes.  You don’t need to see the object in the finder, just stars to let you center where it is relative to those stars based on your atlas.
Dave
#18 Tom3
Tom3
Posted 16 July 2020 - 11:36 PM
I have SkySafari on my phone too so there is redundancy of LST.
#19 rcwolpert
rcwolpert
Posted 17 July 2020 - 05:58 AM
lol.gif  Me too!
