PixInsight: EZ Processing Suite - the suite for your processing needs
237 replies to this topic
#1 darkarchon
darkarchon
  • Loc: Switzerland
Posted 24 July 2020 - 06:45 PM
Hello everyone,
I have been coding in the past few weeks on a set of scripts which I have dubbed the EZ Processing Suite. Although it doesn't do only processing and the script collection is still small I still want to share it with you guys.
It's still early days and heavy under development and constantly improving. Just a few minutes ago I ported all the scripts I had to my new EZ Common Runtime 2.0 - so yeah expect things to not work 100% smoothly or break. Some scripts will require StarNet++ either running in PI or a mask generated by StarNet++ from the application.
Ok long story short, let me tell you what the EZ Processing Suite contains.
This is the base I have coded all scripts on. All scripts feature similar features (where applicable):
  • How-to use button with prerequisites and steps to apply the script effectively
  • Able to run on previews with multiple tabs to apply the results
  • Results can be applied to the whole image afterwards
  • Extensive console output of the current state and processes happening
  • Settings are stored throughout multiple sessions after applying them
  • Previews in the script respect original STF or if none applied, compute their own
  • Works on RGB and Luminance images
  • Possible to change target image and previews within the scripts
EZ Denoise
A script based on Jon Ristas' TGVDenoise + MultiscaleMedianTransform method. Works best in linear image state.
Main features:
  • Generate Masks and Processes for TGV Denoise
  • Evaluate the whole denoise process on previews and compare against the original
  • Adjust mask settings freely to find the settings that work for you
  • Does the whole denoising process for you
Screenshot with example result:
EZ Decon
A script based on OkeWoke's (a friend of mine) deconvolution method by running deconvolution without deringing and replacing the stars with an extensive star mask afterwards. Uses StarNet++.
Main Features:
  • Automatically generate fitting star masks with StarNet++
  • Quickly edit star masks and compare how well they cover the image
  • Automatically generate PSF for your image
  • Adjust necessary deconvolution options at will with semi-sane defaults
  • Evaluate the whole deconvolution chain over previews and compare against the original
Screenshot with star mask window and controls visible:
EZ Soft Stretch
A script that will use the HistogramTransformation to stretch an image to a non-linear state with automatic black point detection and reliable median calculation based off my own methods of stretching images to non-linear.
Main features:
  • Adjust target median and stretch aggressiveness with easy to use sliders
  • Get a live computed preview and information about your result, what you see is what you get
  • Using linear regression to calculate blackpoint based on summed histogram
EZ Star Reduction
Utilizing StarNet++ this will generate a reliable contours mask which then uses MorphologicalTransformation to reduce star sizes reliably. Easy to use and good, not too strong results.
Main features:
  • Generates and adjusts a proper star mask for you
  • Simple controls that don't need much tweaking
  • Reduces stars effectively
Screenshot of the UI:
Example result before/after
EZ Live Stack
Not really a processing addon, but it does exactly what it says. It will monitor a folder for incoming files and stack them together, giving you a good preview of what the nights' result will be.
Main features:
  • Can be started in the middle of any image run and will integrate everything
  • Allows the use of master calibration files for a better stack preview
  • Can export the live stack and load it in later if you want to continue with the live stacking session without restacking previously stacked files
  • This also works multi-night since it persists throughout saves
  • Will perform rudimentary basic rejection (as good as you can get I guess)
Screenshot with example stack:
And that is it so far. More is to come, more features for each script too as I know myself. If you have any ideas let me know.
If you made it this far you might be interested in actually getting it, the repo URL is https://darkarchon.i...et-box.ch:8443/
UPDATE: NEW REPO URL
To note: to report issues please come to my Discord and post it there. I am very rarely on CN and probably won't see if people post issues here. The discord link is embedded in the exit message of the scripts.
Thanks for reading and have clear skies!
Edited by darkarchon, 25 July 2020 - 03:00 PM.
  • StephenW, John_K, dswtan and 52 others like this
#2 Aaron_tragle
Aaron_tragle
  • Loc: Richmond, Virginia
Posted 24 July 2020 - 08:18 PM
Can't wait to use this in my workflow, running different settings for denoise in real-time will be a game changer for me.
  • darkarchon and hkclover like this
#3 mewmartigan
mewmartigan
  • Loc: outside of Pittsburgh, PA
Posted 24 July 2020 - 08:27 PM
They sound neat. I will give them a try.
  • darkarchon likes this
#4 ezwheels
ezwheels
  • Loc: Oakland, CA.
Posted 24 July 2020 - 08:40 PM
I can vouch for these scripts. They are very well designed and work extraordinary well.
  • psandelle and darkarchon like this
#5 matthew_carlos
matthew_carlos
Posted 24 July 2020 - 08:47 PM
Works. Very Slick. This plus Cuda Starnet ++ marriage makes it EZPZ.
#6 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 24 July 2020 - 08:48 PM
I have seen darkarchon on the NINA Discord Forum.  Is darkarchon one of the developers?
#7 ezwheels
ezwheels
  • Loc: Oakland, CA.
Posted 24 July 2020 - 09:41 PM
Yes, he is one of the devs. He is on the NINA Discord very regularly and is very generous with his time in helping everyone with NINA and processing.
  • Aaron_tragle and darkarchon like this
#8 Jim Waters
Jim Waters
Posted 24 July 2020 - 09:44 PM
waytogo.gif  Thanks.
#9 kisstek
kisstek
Posted 24 July 2020 - 10:26 PM
I saw Cuiv's video on the eZ suite and was impressed enough I ran out to install it and try it out. Unfortunately, since I have a Mac, I have to wait until the next release of PixInsight to be released before I can try it.
And wait for NINA 1.10 to be released.
And wait for APT to be released with autofocus.
And wait for a job offer.
And wait for the Monsoon to end.
  • Jim Waters, David Boulanger and Baron von Smoogle like this
#10 mrszymon
mrszymon
Posted 25 July 2020 - 03:26 AM
You can use the EZ Suite with Mac at the moment. Three options:
1. Go back to an older PI version — the previous one doesn’t enforce signed libraries and can work with StarNet++
2. Remove the signature from the current PI binary. The PI folks don’t like this idea so I won’t provide instructions but it works.
3. In EZ Suite provide it with a Star Mask rather than trying to autogenerate it with StarNet++. You could use the Star Alignment process to create a mask, for example, or you could use the command line version of StarNet which works as a standalone on the Mac.
The EZ Suite is a real time saver, automating things that you were probably doing anyway and making it easy to use. I love it :-)
#11 darkarchon
darkarchon
  • Loc: Switzerland
Posted 25 July 2020 - 08:03 AM
Update:
EZ Common Runtime 2.1:
- add generic doPixelMath
- Bugfix selecting empty main view locking up scripts
EZ Decon 0.12:
- adjust star mask with adding custom ellipses (thanks for Herbert Bornemanns GAME script)
- ellipses can be added to star mask and removed from star mask to fine tune the auto generated result
  • Jim Waters, rdmarco and calypsob like this
#12 telfish
telfish
  • Loc: Adirondack Mountains NY
Posted 25 July 2020 - 08:11 AM
This looks really interesting, will download and try it out, anything that makes PI more accessible is a great thing. Many thanks for your efforts and especially keeping this public.
#13 calypsob
calypsob
  • Loc: Virginia
Posted 25 July 2020 - 08:39 AM
WOW I think I might be able to do an entire workflow in PIxinsight with this
#14 darkarchon
darkarchon
  • Loc: Switzerland
Posted 25 July 2020 - 08:42 AM
You can get pretty far.
Here are two examples I did using almost exclusively using those scripts.
  • Jim Waters, psandelle, mikewayne3 and 8 others like this
#15 Dereksc
Dereksc
  • Loc: Santa Cruz, CA
Posted 25 July 2020 - 01:25 PM
darkarchon,
I have been using PI for over 3 years. Even though I am familiar with a lot of PI's capabilities, I am still trying to improve my workflow (efficiency, repeatability) and quality of final image. I think EZ Processing Suite is going to give me a significant improvement in both. So far I have just used EZ Decon. I am very impressed! The tool layout and process flow is clean and logical, you have included very useful advice for using the tool. The default tool values worked well on my images and gave me a great starting point for fine tuning. The way that you track deconvolution trials with additional tabs is great - it makes the iterative process much simpler to control and keep track of.
This looks like it is going to be an incredible resource. Thanks for coming up with the idea, for all your time and effort in developing the scripts and for making EZ Processing Suite available to everybody.
Regards
Derek
  • deuscaput, mrszymon, PhotonHunter1 and 2 others like this
#16 santafe retiree
santafe retiree
  • Loc: Santa Fe, NM
Posted 25 July 2020 - 01:38 PM
Thank you for this great contribution.  Is there a graceful way to exit the script mid-process? I do not see a "Cancel" button. Cheers,  Tom
#17 darkarchon
darkarchon
  • Loc: Switzerland
Posted 25 July 2020 - 01:45 PM
darkarchon,
Regards
Derek
Thank you very much for your kind words Derek, it means a lot to me.
Just close the script with the [x] at the top and cancel running processes. There is no cancellation of running processes currently implemented from via script-side.
Edited by darkarchon, 25 July 2020 - 01:45 PM.
#18 terry59
terry59
  • Loc: Colorado USA
Posted 25 July 2020 - 01:59 PM
Thank you very much for these. When I set things up PI advised me that the repository is unsecure and that future versions won't allow it. I assume you are aware of this
#19 darkarchon
darkarchon
  • Loc: Switzerland
Posted 25 July 2020 - 02:00 PM
I'm actually not but I might migrate it to https at some point. Thanks for notifying.
#20 Jim Waters
Jim Waters
Posted 25 July 2020 - 02:39 PM
Hi darkarchon -
I just got this error message when starting up PI.
"http://darkarchon.in...et-box.ch:8888/: Couldn't retrieve repository information (unknown reason)."
#21 darkarchon
darkarchon
  • Loc: Switzerland
Posted 25 July 2020 - 03:00 PM
Yes I have just migrated it to HTTPS
Please use https://darkarchon.i...et-box.ch:8443/ as the new repository URL
  • SeymoreStars likes this
#22 Jim Waters
Jim Waters
Posted 25 July 2020 - 03:07 PM
Thanks darkarchon.
#23 darkarchon
darkarchon
  • Loc: Switzerland
Posted 25 July 2020 - 04:31 PM
Reminder: Repository URL is now https://darkarchon.i...et-box.ch:8443/
Update:
EZ Star Reduction 0.6:
- Added Adam Blocks Star De-Emphasis Mode
2020-07-25 23_30_42-EZ Star Reduction v0.6 © 2020 S. Dimant EZ Common Runtime v2.1.png
Also further update:
EZ Common Runtime 2.2:
- fix for STF not generating when view that it is being applied to has no STF set
- fix for numeric boxes (and possibly other elements) resetting their values making it impossible to type
Edited by darkarchon, 25 July 2020 - 07:28 PM.
  • Jim Waters, Dereksc, gundark and 2 others like this
#24 PhotonHunter1
PhotonHunter1
  • Loc: Northwest Suburbs of Chicago
Posted 25 July 2020 - 09:16 PM
Wow, this is amazing work! I echo Derek’s comments, Thank you for taking the time to develop, making this available, and keeping it public. Cannot wait to download and give it a test drive.
#25 terry59
terry59
  • Loc: Colorado USA
Posted 26 July 2020 - 08:10 AM
Thank you....I installed these on my desktop with the secure connection and no complaints from PI
