Any ideas?
How to remove Newton Rings in post processing?
#1
Posted 30 July 2020 - 11:14 AM
- philmor56 likes this
#2
Posted 30 July 2020 - 11:42 AM
Flats might help.
But using tilt adapter might be better solution.
- Paul Hyndman likes this
#3
Posted 30 July 2020 - 11:48 AM
Separate the 2 surfaces causing the Newtons rings. They are caused by interference between a lens and a flat surface, usually has to have the lens resting on the flat surface. Also only really met them with monchromatic light.
Next question is: Are we talking Airy rings not Newton rings?
#4
Posted 30 July 2020 - 01:32 PM
Don't know if Stargazer has this but here is one that I noticed "Newton Rings" on. I shot this one with the PGR.
Edited by chemman, 30 July 2020 - 01:58 PM.
#5
Posted 30 July 2020 - 04:11 PM
Heya,
Flat calibration, either a flat made during acquisition, or a pseudo flat done in post processing. Ideally remove it in acquisition (this is covered in my tutorials) either via real time flat overly in FireCapture via defocus or via a diffuser. Ideally just stop them from happening with a tilt adapter all together (especially for a full disc).
If you can attach the file you want to see the newton rings processed out of, I can attempt it purely in post and if successful share a step by step how to via Photoshop CS5.1 (old version so should work in anything and may even work in Gimp with similar naming).
Very best,
Edited by MalVeauX, 30 July 2020 - 04:18 PM.
- ilan_shapira likes this
#6
Posted 01 August 2020 - 08:00 AM
Hi there:
I'm having the same frustrations. I've tried using flats (as per Martin's and other's tutorials but to no success (long story)), and I'm waiting on my tilter.
This is a recent capture with my 2x barlow. I'd love to find a way to get rid of the rings in post. I've tried but my understanding of P/S is still limited.
Any advice, as always, is appreciated!
Thanks in advance.
- Stargazer3236 likes this
#7
Posted 01 August 2020 - 08:31 AM
Hi there:
Thanks in advance.
Did you do a flat calibration during acquisition? Ie, either defocus or with a diffuser of some kind? This is key if you do not have a tilt adapter (and still important even with a tilt adapter due to gradients).
Very best,
#8
Posted 01 August 2020 - 08:53 AM
Very best,
Thanks for the reply Marty.
Yeah, I've tried the defocus flat multiple times. Every time I apply the flat, as per your video, the flat "explodes" around the capture in a kind of corona effect, making processing impossible...
Maybe I'm missing something here.
(ZWO is apparently modifying their adaptor and the back-orders are piling up, so I've been waiting on that. My dealer is hoping his next shipment may have them)
Thanks again.
- MalVeauX likes this
#9
Posted 01 August 2020 - 10:12 AM
to come back on the question about post-processing.
Yes there are tricks produce good results in most of the cases, if NR's are present on the images.
You can look at these info on CN: https://www.cloudyni...es-from-images/
en another one in Dutch at https://www.astrofor...em-en-oplossing (maybe google can try to translate)
Paul
#10
Posted 01 August 2020 - 08:52 PM
It's been many, many years since my solar imaging days but... most of my post-processing efforts to deal with NR were lackluster at best (flat fielding actual or pseudo flat fielding) when sufficiently applied to remove traces of the rings, also removed detail in hi-res (SBIG STL11K w/90/90/30 Coronado setup). The best solution for me, as mentioned above by Tapio, had been to use a tilt adapter. IMO, it is easier to start with the best raw images rather than deal with uh-ohs later on.
I no longer maintain a website, but FWIW some of my notes on NR can be found here.
https://web.archive....tons-rings.html
#11
Posted 27 April 2021 - 05:05 PM
Hi there:
Thanks in advance.
This took me 25 seconds in ImageJ using FFT blob removal techniques. Not kidding. Literally less than 30 seconds. This technique is BEAUTIFUL!
JT
Edited by jt_3232, 27 April 2021 - 05:11 PM.
- philmor56 and torsinadoc like this
#13
Posted 22 May 2021 - 08:45 AM
JT
I played with your image as well. Here are the results that took me less than 1 minute to do.
Jaxon
Hi Jaxon
Wow, those are really good results!
So, after seeing your reply I eventually found and downloaded ImageJ.
Um... really above my level of knowledge at this stage and age !
I dropped an image into the program and played around a bit and I found the FTT function and that "flat" window popped up but that's about where I lost it. I spent a good half hour trying to do something and, well something's not clicking.
How about a quick workflow for that 25 second fix. Maybe then I can figure out what is being done.
If this works as good as it seems you are indeed a life saver!
Thanks again.
Cheers
#14
Posted 22 May 2021 - 11:35 PM
Hi Jaxon
Thanks again.
Cheers
Josh (jbalsam) did a great job here https://www.cloudyni...es-from-images/ which was posted above. However, I think it can be simpler than what he does.
1.) Open ImageJ (by clicking the Windows search bar and typing "imageJ" and clicking the result)
2.) Open the photo using File->Open and navigating to the image.
3.) Calculate the FFT of the image by going Process->FFT->FFT
4.) The centered log-magnitude stretched FFT of the original image is shown, zoom in towards the center using Ctrl+scroll wheel
5.) Look for the odd disparities. Useful Aside: The FFT gives you back the image transformed into the frequency domain. If you invert this back, you get the exact same image back. The frequency domain shows how the image is composed of different frequencies. In the centered, log magnitude FFT, the very center is frequency 0 or the "DC" (like direct current vs AC), while the further away from the center, the higher the frequency. The 0 frequency is the average value of the entire image, which is usually a very very large number, so it is very bright. The rest of the FFT tends to be relatively smooth, depending on the image content. If you had a large picture of a striped shirt, you might think you'd see a specific frequency of how often those stripes occur and you would be right! However, in the FFT, the frequency is always rotated 90 degrees relative to the actual image's frequency. So, if his shirt had very consistent stripes going up and down, you would see a large spike in the FFT close to the center (but not on the center) that is on the left and right of the center. (note, up and down stripes results in spikes on the FFT on the left and right side). In our image, we see these big frequency stripes going left to right. So, we should expect a spike to occur above or below the center. Indeed, we do see that spike. Note: the stripes don't necessarily always go up and down or left and right, they could be at angle, and the FFT would show the corresponding spikes oriented 90 degrees from the image's stripes.
6.) Drag and select a box around the spikes and hit the delete key to remove the spike. (Removing the spike in the FFT will remove that specific frequency component in the actual image, which is what we want).
7.) Run the Inverse FFT by going Process->FFT->Inverse FFT.
8.) Inspect the resulting image. Satisfied? Yes- Save it and show it off! No- Try making bigger (or smaller?) boxes around the frequency spikes.
8.) Voila!
Let me know if this was helpful!
Take care,
Jaxon
- R Botero, chemman, MalVeauX and 2 others like this
#15
Posted 23 May 2021 - 07:32 AM
8.) Voila!
Take care,
Jaxon
Wow... !
Voila indeed!
Got it, thanks for clicking on the light bulb!
Even with my tilter I've noticed some ringing here and there and this is a wonderful fixer.
Thanks again for teaching this old dog a new trick!
Cheers
#16
Posted 23 May 2021 - 07:51 AM
Wow Jaxon that is a great explanation. I will definitly be giving that work in ImageJ a try. I shot 200 frames yesterday complete with Newtonian rings. The flat was near useless but had to have the event that was unfolding at the time.
Your process Jaxon looks to be specific for each image so even if I can get the process down to 1 minute my shot will take more than 3 hours of processing. Is there a Batch switch on ImageJ?
Thanks for the tutoring.
Chuck
#17
Posted 23 May 2021 - 09:57 AM
Chuck
Hi Chuck,
I actually just did my semester Master's DIP course project looking at the automatic removal of Newton's rings. This turned out to be very difficult, and the only good way I could make this work live was using an ideal band stop filter. Needless to say, for best results, it is best to do it manually.
For a video, I do not know if there are scripts on ImageJ or how to write one, but it shouldn't be hard to make one do that.
For your video, you might consider making a finalized image and then apply NR removal. This would be the simplest way and should still work fine. In fact, it might be easier to see the NR spikes on the FFT if you wavelet sharpen the image first. However, I can only speculate as I only worked with single processed images.
Please ask any other questions you may have.
Jaxon
#18
Posted 23 May 2021 - 08:40 PM
Heya,
Very best,
Marty here is one I am working with today. I tried a defocused and a trashbag flat but the little rings remained. Sometimes I can use up to 100 flats and get it to work for a while but it seems like after a while they come back. I have used a tilt adapter but not spent enough time adjusting it to get satisfactory results. That will be coming soon. I am going to work with the 2" barlow I got from Harry Siebert. It has a T2 connection on the top for the camera. I have a Baader clicklock 1.25" adapted to T2 for visual. These are Harry's Focus adapter series and have 110mm distance a T2 extension tube needs to occupy. I am going to adapt a JMI electric focuser in that 110mm path to move the camera closer and further and hopefully get a some +- 2x adjustment of amplification from the telecentrics. Marty, Should the tilt adapter be directly attached to the camera or attached to the Barlow T2 100mm up the light path?
Side question for you Marty. The scope I am using LS100MT is 714mm focal length but with the two etalons it is extended by about 100mm to 814mm, is that the new focal length or should my calculations still use 714mm?
Jaxon, I was able to do a pretty good job of removing from a flat I shot with distinct Newtonian rings. But when I tried to find the "Spikes" you mention in step 6 of post #15 I obviously can't locate them properly. I ended up with a big blurry image when I did an Inverse FFT. Got some suggestions? The image I am working with is the same one for Marty.
Chuck
Here:
Edited by chemman, 23 May 2021 - 08:45 PM.
#19
Posted 25 May 2021 - 10:45 PM
Chuck
Here:
Sorry for the delayed response, I've been moving.
So, I'm having a hard time figuring out what exactly the Newton rings are here. Is it the 3-4 almost vertical lines right underneath the solar spot/flare? If so, that is a real challenge for a few reasons. One, the rings are curved, meaning the FFT won't be a spike, but more like a hazy part that is just slightly brighter than the surrounding areas. If you zoom in on the FFT you will see sort of a "cone" shape. This is because the frequencies are changing direction (curved lines) thus it is not a single spike. So you have to delete a large portion. The second issue is that doing it for this specific frequency causes issues on the edge of the Sun in which the curve is the same orientation.
I learned more from this example.
Takeaways:
1.) images of the Sun which include parts of the edge with the same orientation as the Newton's rings are hard to work with.
2.) Not all Newton's rings look the same.
3.) More curved Newton Rings are even more difficult to work with.
Thanks for letting me try your image, it is a really nice pic. Here is my best result (note the distortion on the edge):
Jaxon
