Who still owns the Tasco/Vixen 8v telescope?
catadioptric classic observing report reflector
12 replies to this topic
#1 saturnViktorSakurai
saturnViktorSakurai
Posted 30 July 2020 - 10:21 PM
If someone still own one of these, let me know if it really works well? Have a good resolution? A good reach?
Could you post pictures of observations of the planets?
We can also make a comparison with the Celestron Powerseeker 127eq to the Tasco/Vixen 8V
both have very similar focal aperture...Would it make a big difference? Even though they are both Catadioptric/Bird-Jones telescopes?
The 8v is from 1990s... Does the 8v continue to work well? With good observation and long reach?
What do you think of him? Forgetting collimation ... what do you say about his performance?
Post pictures of your skies, if you have one, or lets compare with the Celestron, ok?!
Edited by saturnViktorSakurai, 30 July 2020 - 11:30 PM.
#2 deepwoods1
deepwoods1
  • Loc: Connecticut
Posted 30 July 2020 - 10:46 PM
I do not currently own one, but if it comes with the original mount, you'll find it much more stable than the Powerseeker.
  • Defenderslideguitar and saturnViktorSakurai like this
#3 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 31 July 2020 - 06:46 AM
There are a few observing reports for the 8V scattered around CN. (And some on the SGL Forum, too.)  It's not a very good design, though Vixen executes it well.  I wouldn't trust the cheaper versions for decent performance.  Seems these have something like a Barlow lens in the focuser tube -- and how stable are they after racking in/out 100s of times?
An 8V popped up at a low price a few years ago, and I thought about buying it.  They're an uncommon Tasco, and I like the concept and the appearance as a Display.  If the 8V is made as well as that Vixen VMC200L that I had, it would easily out-perform the PowerSeeker 127.
#4 Astrolite
Astrolite
  • Loc: S. Central Pennsylvania
Posted 31 July 2020 - 10:48 AM
Yes I own one.
The purchase was made strictly for the mount. After having read all the negative print about this design and the difficulties in collimating it, I actually have never even looked through it. I found that it has the exact same focuser as my Celestron C4.5 and a swap was made because it was in slightly nicer condition. I also used the finder shoe on my C4.5. So it's just leaning in a corner, kinda a parts scope. The mount however, has been put to good use! Excellent mount!!
  • deepwoods1, Bomber Bob, Defenderslideguitar and 1 other like this
#5 saturnViktorSakurai
saturnViktorSakurai
Posted 01 August 2020 - 12:47 AM
ok, Astrolite! I really like the Newtonian standard. But tell me what do you think of the image through the telescope? Are they good or bad? Can we see planets clearly? would it still serve you well these days? I’m thinking in buying one...Can you post planets images, pictures of both telescopes?
#6 GreyDay
GreyDay
  • Loc: Southport UK
Posted 01 August 2020 - 04:11 AM
I was given a powerseeker 127.. notice i say "given". personally i wouldn't buy one! The bird jones design when done correctly can work as well as any newtonian, the powerseeker has not been done that well!
The views no matter which EP you use are only sharp for75-80% of the field the outer 20% sacrificed to coma. The focuser has tons of slop, collimation is made diffucult by only having philips screws, you have to take out the corrector from the focuser to collimate... i could go on.... mine languishes in the top cupboard, i wouldn't give it away! i wouldn't want to pass on the frustration and misery!
Like everyone here has said, i'd have the 8V for the mount, If you just want a  5" Newt buy the Astromaster 130P or Celestron C6-N. Anything as long as it's not bird jones!
#7 Compressorguy
Compressorguy
  • Loc: Clayton, NC
Posted 01 August 2020 - 06:57 AM
I had one due to curiosity and it was only $75. Like others have said, the scope is just ok and annoying to collimate. The views are acceptable but underwhelming. The original rings Tasco used are very prone to dent the tube and most are. The Vixen Polaris mount that came with these on the other hand is fabulous. I put a RA drive on it. Unless you can get it cheap for the mount, I would pass. I moved mine on shortly afterwards.
https://www.cloudyni...81786-tasco-8v/
  • Bomber Bob likes this
#8 Stephen Kennedy
Stephen Kennedy
  • Loc: California
Posted 06 August 2020 - 12:39 AM
I have one and would say the optics are good (Vixen made this design about as good as it can be) and the Vixen Polaris GEM is outstanding for its vintage.
#9 mitsos68
mitsos68
  • Loc: Athens - Hellas.
Posted 07 August 2020 - 06:24 AM
I have one Vixen model too. Good optics but the main mirror needs a fresh coating. Comes from 1985 with Halley comet sticker.
Regards
Dimitris
Athens-Greece.
#10 mitsos68
mitsos68
Posted 07 August 2020 - 06:25 AM
Please erase..
Edited by mitsos68, 07 August 2020 - 06:25 AM.
#11 saturnViktorSakurai
saturnViktorSakurai
Posted 09 August 2020 - 05:44 PM
Yes I own one.
Friend Astrolite, ask me a question? What is this eyepiece of the photo of the 8v that sits there at the base of the hour circle??
Edited by saturnViktorSakurai, 09 August 2020 - 05:46 PM.
#12 Astrolite
Astrolite
Posted 09 August 2020 - 05:56 PM
Image through the telescope. I have never looked through the 8V or photographed anything through it. The Celestron C4.5 gives wonderful views of the planets for its size, I have also never photographed through it.
I think what you are referring to is the polar alignment scope. It was standard equipment on the Vixen Polaris mount that came with the Tasco 8V. They are rather hard to come by otherwise.
  • saturnViktorSakurai likes this
#13 clamchip
clamchip
  • Loc: Seattle
Posted 09 August 2020 - 08:42 PM
Here's mine:
https://www.cloudyni.../?hl= tasco 8v
Robert
Also tagged with one or more of these keywords: catadioptric, classic, observing report, reflector
