I've decided to rebuild/tune my Eq6 mount
6 replies to this topic
#1 moxican
moxican
  • Loc: Toronto, Canada
Posted 01 August 2020 - 11:35 AM
The mount in subject is the venerable NEQ6. I had some discussion about this mount here CN, but now I have decided to just bite the bullet and do a tune up as it was not performing optimally anymore.
I was following the video tutorial from DeepSpace Products (thanks Ed). It is very thorough and easy to follow. So far the NEQ6 is almost completely apart. My main idea was to regrease, replace the 4 worm gear bearings to SKF ones, DIY altitude adjustment and adjust the entire system to top performance.
So far so good, although I had some unexpected issues. On the large tapered bearing located at the bottom of the RA axes, there are 3 small retaining screws, one 2 of them was Philips screw and easy to remove, while one (the bottom one) was a Robertson and it was full of some sort of dirt that I had to dig out from the head of the screw. I bought this mount new so I don't know what this was.
Furthermore, although I was not planning to replace the 6 main shaft bearings (3 on each shaft), 3 of them is bad, one from the DEC axes is really bad. It binds, difficult to turn and it also makes some suttle noise. So, I think I will replace all 6 of them, might as well. Chances are that if 3 is gone from the 6, the other 3 will follow shortly.
I did not take the motors out yet, but I could check the gears and there is a very visible/hearable backlash on both axes, especially on the DEC axes. I will update as I continue the disassembly. Any suggestions are welcome...
#2 Xeroid
Xeroid
  • Loc: USA
Posted 01 August 2020 - 11:42 AM
Just curious but how old is your NEQ6 mount?
#3 moxican
moxican
Posted 01 August 2020 - 11:48 AM
5 or 6 years old, I don't remember exactly.
#4 Xeroid
Xeroid
  • Loc: USA
Posted 01 August 2020 - 12:44 PM
Thanks, good to know and good luck with the rebuild!
#5 moxican
moxican
Posted 03 August 2020 - 11:40 AM
I ran into a little problem. I have a little hard time finding the right bearings for the aforementioned 6 bearings. The part number is 6008 2RSH. While I can find bearings I am at lost to which is the brand to go for, and whether it's worth going ceramic or not.
I heard SKF and URB are good brands. I have already ordered the small worm bearings, they are SKF. I was a little disappointed though that they are not that easy to spin. They are not binding or any of that sort, it is their design.
What I'd like to achieve however, is something like this: https://www.youtube....h?v=rQ2C56jQSd4
I understand that it is done by Darkframe Ltd. Is something like this only achievable by hybrid ceramic bearings? I can buy all six steel bearings from SKF for the price of one hybrid bearing.
#6 moxican
moxican
Posted 08 August 2020 - 04:12 PM
I've just finished reassembling the stepper motor/gear drives for both RA and DEC axes. It took me over an hour to adjust gear spacing in the RA axes. It was binding a bit and I had to find a happy medium where it was not binding anymore and still gave acceptable results in terms of backlash play.
I was really curious of the rotational speed of the motor under sidereal rate tracking so I hooked it up to the main board and gave it some test. You can see the video here: https://www.youtube....eature=youtu.be
#7 kyle528
kyle528
  • Loc: SE Ohio
Posted 08 August 2020 - 05:48 PM
Sealed/shielded bearings will not spin "freely" because they are packed with grease. If they do, something is wrong. A good way to test a bearing is to put a load on the inner race parallel with the bore of the race, and turn the outer race, it should be completely smooth, if you can feel any sort of interruptions, it's bad.
