NGC 6992 - The Viel Nebula
astrophotography imaging refractor
6 replies to this topic
#1 pcos
pcos
  • Loc: Honeoye Falls, New York
Posted 01 August 2020 - 12:21 PM
The other day I shared an image of NGC 6960 - the Witch's Broom. NGC 6992 is, of course, another prominent part of the Cygnus Loop formation - the remnant of an expanding shockwave bubble from a star that went supernova about 10,000 years ago.
This was taken on the evening of 7-24-20.  Despite the fact that there were some early clouds, I set up both of my imaging rigs and was capturing photons for most of the evening.  We did have some clouds roll through - causing the guider to loose the guide star - and creating a chain of events where Sequence Generator Pro shut things down, waited a bit and then later - when the clouds had moved off - started the sequence back up. I've had the automation finally working for me for the past month now and  it's starting to pay off.
The framing on this one is a little tight for my focal length - but I think I got most of it in ok.  I planned this out the day before using the mosaic tool in Sequence Generator Pro to lay out the precise framing.  When I executed the sequence last night, the rig slewed to the object, plate solved to confirm location and current angle and then using my Flacon rotator, spun the camera to frame it just so….  Again - the automation is paying off.
Here is the image in Astrobin: https://astrob.in/6ktcpv/0/
Thanks for looking....
Here are the image details:
65 x  120 seconds
50 x 2 second Bias exposures
25 x 120 second Dark exposures
50  Flats
Scope:  William Optics 132mm FLT F/7 APO
Guide Scope:  Apterna 60mm
Camera:  ZWO ASI294MC-Pro
Guide Camera:  ZWO ASI290Mini
Focus Motor:  Pegasus Astro Focus Cube 2
Field Rotator: Pegasus Astro Falcon
Mount: Ioptron CEM60
Polar Alignment: Ioptron Ipolar integrated alignment cameras
Capture Software:  PHD2 Guider, Sequence Generator Pro controller
Image Processing:  Deepsky Stacker, Pixinsight, Photoshop
  • elmiko, SambaChoro, SeymoreStars and 4 others like this
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 01 August 2020 - 12:40 PM
Very nice imaging and processing pcos...!
  • pcos likes this
#3 Dynan
Dynan
  • Loc: NOLA
Beautiful! Nicely done!
In checking your misspelling of 'Veil', I entered 'viel' in the address bar and got this:
http://www.vielewelt...df_en/capra.pdf
Again, beautiful image...
  • pcos likes this
#4 pcos
pcos
Posted 01 August 2020 - 12:53 PM
That's hilarious! Yes - there must be a very deep link there!  Some sort of neural-quantum entanglement no doubt.....  lol.gif
Pcos
  • Dynan likes this
#5 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 01 August 2020 - 05:26 PM
Very nice image!
How do you like your Pegasus Astro FocusCube v2 so far? Do you recommend it? And why did you go with the ZWO one?
#6 pcos
pcos
Posted 01 August 2020 - 07:58 PM
Very nice image!
Thank you your feedback on the image - much appreciated!
I originally tried the Focus cube2 on my first astrophoto rig.  At the time - it was the only one that was in stock and was something I could get to work with quickly.  My experience with it and Pegasus Astro has been very positive.  It works extremely well and I have found Pegasus Astro support to be very proactive.  I get responses to questions from them within hours.  When I was trying to figure out if it would fit my scope  - they provided lots of photos to help show that it would work.  So based on this I got a second unit for my second rig.  I have been very satisfied with it as well.  If the ZWO focus motor were available I might have gotten that one but it wasn't  - I am very satisfied with where I ended up. I have now purchased a quite a few  of Pegasus Astro products and I continue to find them to be of high quality and good value.
Hope that helps...
PCos
#7 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 01 August 2020 - 08:58 PM
Hope that helps...
PCos
Cool, thank you very much!
Also tagged with one or more of these keywords: astrophotography, imaging, refractor
