Dual Barrel Eyepieces
12 replies to this topic
#1 bengreen
bengreen
Posted 01 August 2020 - 01:13 PM
Hi. I've seen tons of discussion about 1.25" vs 2" eyepieces. But I haven't been able to find anything about dual sized barrels.
The reason I'm asking is that I finally have a decent grab 'n go fast refractor that's been telling me it would be happy with an eyepiece midway between 5mm & 8mm for planetary.
Among the offerings in this range that I've been considering are the Morpheus 6.5mm and Russell 6.7mm Koenig. I do like wide. Both have dual 1.25/2" barrels.
Are there any practical benefits or caveats regarding this barrel design other than the convenience of not having to bother with adapters?
In reality, the Russell choice may be moot. I've been happy with the Koenigs I've bought from Gary but he seems to have a vendetta against his own design, declining to sell the 6.7 - 1.25/2", even though it's been listed as in stock on his web site for years. He said a customer told him it had damaged their diagonal.
Edited by bengreen, 01 August 2020 - 01:23 PM.
#2 Brian Carter
Brian Carter
  • Loc: Atlanta, GA
Posted 01 August 2020 - 01:21 PM
Nope, it is 100% about the convenience of not needing adaptors.
i hate adaptors. I hate having to fiddle with anything in the dark, in the middle of the night.  If it’s cold, I hate it even more. A long time ago, bought a bunch of 2” adaptors for my 1.25” eyepieces so I never had to go back and forth again.  One of my better decisions.
  • photomagica, 25585, bengreen and 2 others like this
#3 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 01 August 2020 - 02:53 PM
Careful.  1.25" eyepieces with 2" skirts are still 1.25" eyepieces.
And in a refractor, if used as 2", the 1.25" section can hit the diagonal mirror.
Specifically, Morpheus eyepieces (except the 17.5mm) have their focal planes at the shoulder of the 1.25" section.
The 2" outer is more a convenience for newtonian users, and, even then, the eyepieces will require a LOT of out focus if used as 2".
I use the Morpheus eyepieces exclusively as 1.25" eyepieces in my newtonian so the focal points are not dramatically different than other eyepieces.
Of course, Brian's solution is a good one if you don't want to use a 1.25" adapter--simply convert them all to 2" by attaching adapters to each eyepiece.
It's what I ended up doing with the 17.5 Morpheus to make it parfocal with the others.
  • Jon Isaacs, 25585 and bengreen like this
#4 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 01 August 2020 - 04:12 PM
Ask me how I know....
  • Tropobob and bengreen like this
#5 bengreen
bengreen
Posted 01 August 2020 - 04:15 PM
Thanks. If I get one, I'll be sure and check clearances first.
#6 Chuck2
Chuck2
  • Loc: Chicago, IL
Posted 02 August 2020 - 01:07 AM
Simple solution...
When using a Baader Morpheus or Mark IV Zoom in a 2" mirror diagonal, use this inexpensive extension tube to ensure the 1-1/4" eyepiece nose does not hit the diagonal mirror...
https://agenaastro.c...-extension.html
#7 SeattleScott
SeattleScott
Posted 02 August 2020 - 01:31 AM
Yep definitely check the spacing in daylight first. My LVWs are fine but I won’t be buying a 2” prism anytime soon.
Scott
#8 25585
25585
Posted 02 August 2020 - 06:50 AM
A benefit of some adapters is they have smooth noses, so if undercuts bother you, they need not with such a 2" adapter.
#9 *skyguy*
*skyguy*
  • Loc: Western New York
Posted 02 August 2020 - 07:36 AM
The dual barrel16mm Nagler looks pretty ridiculous when it's in the 1.25" focuser on my 5.5" Comet Catcher.  However, it's an amazing eyepiece when matched with the f/3.64 scope. Who cares about looks!
#10 Starman1
Starman1
  • Loc: Los Angeles
Posted 02 August 2020 - 10:31 AM
Simple solution...
That would lift the focal plane of the eyepiece quite a distance out and require a lot more in travel of the focuser.
It would essentially lift the 1.25" shoulder out to where it would be if the eyepiece were used in a 1.25" adapter.
I fail to see the advantage over simply using the eyepiece as a 1.25" with a 1.25" adapter.
#11 RickM.
RickM.
Posted Yesterday, 06:13 AM
#12 Chuck2
Chuck2
  • Loc: Chicago, IL
Posted Today, 03:45 AM
Don,
I was merely offering a solution to your comment above that using a dual barrel type Baader eyepiece in their 2" skirt format may strike the mirror in a 2" diagonal. No worries if you add a simple, short, $26 extension.
Correct, a short extension essentially lifts the eyepiece to where it would be using a 1.25" adapter; however, there are advantages. With a short extension you are able to attach Baader's 2.25x matched barlow and filters without the eyepiece sticking precariously from the 1.25" adaptor. In the 1.25" format the barlow doesn't seat well, the eyepiece sits high, looks ridiculous and is not as robust as using the 2" skirt format. At star parties, people constantly try to "steer" my scope by the grabing the eyepiece. If your scope came with a decent focuser with good travel and a 2" diagonal, why not use the Baader's in their 2" skirts?
Just offering user options, for about the same price you can get either a 1.25 adaptor or short extension.
#13 AstroVPK
AstroVPK
  • Loc: Sunnyvale, CA
Posted Today, 11:10 AM
One of the biggest benefits of standardizing to 2" for me has been avoiding two sets of filters. For the price of a few fairly cheap adaptors, I can stay with 2" filters for al my eyepieces.
