Attaching eye piece or Camera without diagonal
accessories Celestron cassegrain equipment eyepieces
1 reply to this topic
#1 arshadwm
arshadwm
  • Loc: Houston
Posted 01 August 2020 - 07:53 PM
Hi. Can nylons guide, if I want to attach my eyepiece or Barlow to a 2 inch barrel of Celestron Cpc 1100 Edge HD without DIAGONAL. which adaptor do I need ? I tried but there is a requirement of adapter With male thread to be attached to the telescope but I don’t know which one. Thank You.
#2 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 03 August 2020 - 04:22 PM
It's called a " 2" SCT visual back ".  You can do a Google search and come back with a thousand sites.
It's a tube with a female 2" x 24tpi thread on one end and a smooth bore 2" on the other with a thumbscrew or click lock to tighten the inserted accessory down.
They range in price from about $20 to over a hundred depending on how fancy you want it to be.
This "straight through" attachment of an eyepiece is always used for collimation of the scope.
And most 2" diagonals can slide right in and easily be turned to one side for a convenient eyepiece position when the scope points low.
Just bear in mind, in the straight-through position the image will be completely upside down.
Also tagged with one or more of these keywords: accessories, Celestron, cassegrain, equipment, eyepieces
