Comet Hunter Mak-Newt Aberrations
4 replies to this topic
#1 janame
janame
Posted 02 August 2020 - 02:45 AM
I'm trying to set up an ES 152mm "Comet Hunter" Mak-Newt which I recently bought used.  I've got some aberrations I need to figure out am looking for advice about what's going on.  My previous experience with reflectors has only been for visual where I haven't been picky about dialing in performance.  I've been using a refractor for AP.
I've collimated the secondary with a cheshire and the primary with a barlowed laser.
I see three issues:
1) On the right side of the frame, stars are oval shaped and pointing toward the center.  On the left side, they're fine.
2) Bright stars have blue and red "jets" coming out in opposite directions.  Effect seems to be significantly reduced in the center, and extreme toward the edges.
3) Diffraction spike on a bright star centered in the frame, with bonus "jets" perpendicular to the spike, and a faint (but very large) concentric halo.
(See image in next post)
I know that the focuser drawtube can impinge on the light path if not racked out far enough.  I suspect this might be the cause of the diffraction spike.  I left the spacers on my camera, but will try again with those removed so I can have the focuser further out.  I don't expect this to be the cause of the jets or the oval stars, though.
Any thoughts on what needs tweaking here?
#2 janame
janame
Posted 02 August 2020 - 02:46 AM
Here's the diffraction spike:
And the full NGC6633 field here:
https://imgur.com/y6Guv13
I didn't take calibration frames, but I see I clearly need to take flats with this scope!
Edited by janame, 02 August 2020 - 02:52 AM.
#3 ks__observer
ks__observer
  • Loc: Long Island, New York
Posted 02 August 2020 - 03:15 AM
Looks like chromatic abberation for colors.
Looks a slight tilt issue for lower right.
But curious what others say.
  • janame likes this
#4 janame
janame
Posted 03 August 2020 - 02:40 AM
What's tilted with respect to what?  The focuser and secondary?  Trying to figure out what I should be adjusting.
#5 ks__observer
ks__observer
Posted 03 August 2020 - 05:59 AM
I believe you need to fix with a tilt adjuster.
I am plagued by similar stars.
https://www.google.c...tilt adjustment
