I'm going to post link for almost any equatorial wedge / latitude base I could find available online, send any link you have and if you have any of these wedges or know any other one, send your feedback about your experience in the comments!
High End Wedges (100€ +)
William Optics Wedge
This is probably the best, sturdiest one you can get with amazing build quality, you can find reviews and many people use it here, probably the best you can buy but also the most expensive.
There are 2 versions, a High latitude one 32-59° and a Low altitude one 7-34°, but if you travel you can make one work for either one with little adjustments as shown by this video by Peter Zelinka (also awesome review):
Video review
Comes without a dovetail bar though.
Agena astro High latitude
William Optics low latitude
William Optics high latitude
First light optics
Astroshop.eu low latitude
Astroshop.eu high latitude
Astroshop/Hercules Stronghold Tangent
I've seen nobody talk about this online, so feedback is much appreciated, seem sturdy and with a good build, a bit on the chunky side though.
It's on the Astroshop aliexpress shop, also called Hercules, it doesn't ship to every country.
Built in Dovetail bar with 3/8" screw.
Aliexpress
TS-Optics ATC Wedge
Another one I've never seen here, seem all metallic with good build quality, also on the small size.
Comes with an adapter with a 3/8" screw.
Teleskop-Express
Amazon UK
AstroTrac Pier Edge
Super expensive option, light, high payload and full stainless steel construction, maybe the best of the best.
Built in plate with 3/8" screw.
Budget Wedges (50€ - 100€)
365Astronomy Mini Wedge
Seems very much like the TS-Optics one, but it's cheaper, might be a good buy for UK users.
Please somebody test it out and tell here!
Plate with 3/8" is built in.
365astronomy
Astroshop/Hercules Wedge
Another aliexpress wedge, seems similar to the iOptron/Omegon one and it's almost the same price too.
It comes with the dovetail bar with 1/4" screw.
Aliexpress
Astroshop/Hercules latitude base with polar scope hole
Yet another aliexpress wedge, this one has a dovetail bar with a 1/4" screw and an adapter for polar scopes or polar master.
You can also buy the custom dovetail separately and it's not that expensive.
Aliexpress
Skywatcher equatorial wedge
By far the most used one here and on youtube, people seem fine with this mount although the knob can get in the way (you can fix this pretty easly with a screw or grub screw).
It's also pretty tall so people have experienced a little bit jiggle while adjusting, but after it's locked down it works perfectly.
It also comes with a dovetail bar with 3/8" screw and a stopping screw to prevent anything from falling.
Astroshop.eu
rothervalleyoptics
B&H photos
first light optics
365astronomy
iOptron wedge
Many prefer this over the Skywatcher one because of the shorter, thicker fork, so it should be more stable while adjusting over the Skywatcher wedge.
Also no knob in the way of the mount and at the same price.
Doesn't come with a dovetail bar at all, so keep that in mind.
astroshop.eu
teleskop express.de
iOptron website
Omegon wedge
Seem identical to the iOptron one and comes with a dovetail bar with a 55mm dovetail 1/4" screw (you would need a 1/4" to 3/8" adapter).
Omegon website
astroshop.eu
Edited by alex180500, 05 August 2020 - 04:14 AM.
