Imaging Jupiter's Moon Thebe
4 replies to this topic
#1 james7ca
james7ca
Posted 05 August 2020 - 03:37 AM
Yes, it's been done at least once (here is what may be the first and only confirmed detection of Thebe posted to CN), but by pure chance I started my own efforts to do the same just last week even before I found the earlier result from June 2019. In fact, as I was processing my images from last Friday I started a search here on CN for "Thebe" and that's when I first saw Karel's (user KpS) earlier post.
I'm still trying to produce a better result (with my existing data) but here is what I've gotten so far using my 9.25" Celestron EdgeHD and a ZWO ASI183MM camera. It's not pretty and some might dispute that I've recorded anything at all (other than noise), but I've placed a marker next to what COULD be Thebe. It seems to be in the correct location and given the magnitude of the field stars that were also recorded the detection seems plausible.
This is the result from doing a software-based tracking on the predicted location of Thebe and thus it required a prior knowledge of Thebe, so it wouldn't quality as a discovery image (that was done by the Voyager space probe when it flew past Jupiter in 1979). To the best of my knowledge Thebe hasn't been imaged very often by ANY earth-base telescope, but there is a report from the famous Pic du Midi observatory where they used a 1 meter scope to capture both Amalthea and Thebe.
[UPDATE]
I found another paper about the images captured at Pic du Midi and in this they show one of the shots that included both Amalthea and Thebe. It's very sharp but Thebe is pretty difficult to see (IMO). Here is the link: https://www.aanda.or.../aa28246-16.pdf
and reference figure #2.
[/UPDATE]
You will note a lot a faint streaks and blurred spots in my image and those are background stars that moved in relation to Jupiter and Thebe. Amalthea is also visible over on the other side of Jupiter, but blurred since it had relative motion against Thebe.
The greatly overexposed objects in this image are Jupiter (of course) and its moon's Europa and Io (furthest on the left). This is actually from a series of images that I took on Saturday, August 1 when the nearly full moon was just over 4 degrees from Jupiter (i.e. not the best of conditions). I have more subs from that night and also a sequence that was taken under somewhat darker skies on Friday night and I'm pretty sure I can produce a better result using one or the other of those data sets (the below image only used one half of my subs as it was a test to see if my software tracking technique was working).
The below image is the result of an integration of nearly 200 subs that were exposed for 3 seconds each using my 9.25" EdgeHD. No guiding, but the session was tracked with an A-P Mach1GTO mount that was "roughly" polar aligned. The seeing conditions were okay but certainly not great and in addition to the nearly full moon Jupiter was pretty far down to the horizon in the worst part of my red-zone light pollution (right over city center).
I should add that my "detection" lacks some of the verification that I like to present when doing this kind of imaging and you can review my image of Miranda that I took in 2019 to see what I consider to be a valid confirmation of a faint or difficult moon.
If I get a better looking and more certain detection then I'll do a more complete discussion of the software techniques I used to process my images. In the interim, I suggest that everyone go over to Karel's post to see additional comments and details on capturing Thebe.
Edited by james7ca, 05 August 2020 - 01:37 PM.
#2 KpS
KpS
Posted 05 August 2020 - 12:02 PM
Excellent result James7ca! You captured Thebe with confidence. To be sure, I created an overlay with CdC. You need to click on the image for the animation.
Edited by KpS, 05 August 2020 - 12:05 PM.
#3 james7ca
james7ca
Posted 05 August 2020 - 12:51 PM
Karel, thanks for the animation. Splitting the image into wavelet layers definitely makes whatever I've recorded much easier to see. I have more data that goes for over 20 minutes so I might even be able to create an animation that shows movement (that would be pretty much a clincher). Plus, I think I've come up with a mostly automated method to track and register to Thebe using PixInsight.
I was just now looking at the plots from Cartes du Ciel (CdC) and comparing their numerical coordinates for Thebe to the NASA/JPL Horizons output and the values were the same to less than one tenth of an arc second. I installed JPL's DE431 ephemeris (2.8GB download) but as I communicated to you earlier I don't think that file even includes data for Jupiter's moons so I'm not really sure where CdC is getting that kind of precision. Note that the Horizons site says that they use both DE431 and JUP310 to determine the ephemeris for Thebe and Jupiter Viewer says the same thing (although Jupiter Viewer seems to throw an error when you request a plot of Thebe). It also looks like Jupiter Viewer is using JPL's SPICE libraries and data to generate their ephemerides.
So, where is CdC getting results that are (apparently) just as good as if using JUP310 (which is supposed to be an additional 1GB download)? I know that these larger ephemerides provide results that can span over thousands of years so I guess it is possible that CdC just has a limited data set that is only good for a few decades. In fact, the user guide for CdC says that they ship with a smaller/limited planetary ephemeris that in only good until the year 2050. But again, they do not mention what ephemerides they use for the moons and as far as I can tell the planetary ephemerides (e.g. DE431) are separate from the ones for Jupiter's moons (e.g. JUP310 and others).
Edited by james7ca, 05 August 2020 - 01:58 PM.
#4 KpS
KpS
Posted 05 August 2020 - 03:33 PM
The timespan of the ephemeris DE431 is thirty thousand years, for the ephemeris Jup310 from the year 1800 to 2200. I agree that DE431 does not contain satellites positions. Interestingly, the CdC can display just those moons contained in Jup310 in the time range from 1901 to 2099. Taking into account your comparison of positions, it follows that the author of the CdC compiled part of Jup310 directly into the main program. I wrote a question to groups.io and I hope Patrick Chevalley will answer.
#5 sunnyday
sunnyday
Posted 05 August 2020 - 03:42 PM
very nice and dedicated work , thanks .
