any raspberry pi users? need some help please
33 replies to this topic
#26 RemcoNL
RemcoNL
  • Loc: Dieren, The Netherlands
Posted 09 August 2020 - 04:39 AM
Ok I’m getting lost here, any tutorials/videos that demonstrate how to operate the simulator?confused1.gif confused1.gif
Don't worry too much about it. EKOS has somewhat of a learning curve (I don't think much more than any other platform.) And you'll grow into it. Basically, most of the "official" tutorials on Youtube use the simulator. But I'll try to create a short video that demonstrates it in more detail.
I've been playing with the idea to start an EKOS channel on Youtube perhaps a good way to get my feet wet. undecided.gif
Also, we're getting a little off topic. But I think most posts demonstrate that there are a lot of viable options. And that a Astroberry/Stellarmate setup can cater to many different situations. Be it directly connected through wifi hotspot or crosscable or over the network wireless or cabled.
If you are taking your setup on the road it might be worth looking into extra storage for yuor PI. I don't have any experience with that but I hear people mentioning SSD's a lot.
Personally, I would investigate a fast thumbdrive that could plug into your PI. But again, no experience.
#27 Bc0428
Bc0428
Posted 09 August 2020 - 05:15 AM
#28 RemcoNL
RemcoNL
Posted 09 August 2020 - 09:12 AM
To paraphrase Mark Twain:
I apologize for the long video - I did not have time to make you a short one.
I never should have mentioned the YouTube channel. I'm really not setup to do these videos.
Nevertheless, I hope you can see through the production quality and the video helps you in some way.
Let me know if I missed something.
https://youtu.be/mgPQ6hxkNKo
O and don't get spooked by the platesolve failure in the end. I've gotten in to work multiple times.
#29 wxcloud
wxcloud
  • Loc: Denver, Co
Posted 09 August 2020 - 11:55 AM
Ekos is a weird quirky beast at times, but I'm getting used to the basics of it. Plate solving, mostly misses for me, not sure why. Too many stars? Bad wifi connection? A 1 forgot to be carried? Most times it fails, but seems to get me in the ballpark.
I do wish it had a framing feature, I have read something about a super mosaic maker in the scheduler, but usually skip the scheduler because I forget it's there.
Kind of don't like that everything you want to use needs to be plugged in and powered before you can change settings. However you can add basic stuff.
Still need to get around to flashing an arm version Debian based image on one of my pis
#30 RemcoNL
RemcoNL
Posted 09 August 2020 - 12:05 PM
Yes she is.
That's why I've adopted the "if it works; don't fix it" mentallity. ;-)
Regarding plate solving. What service do you use?
My solving went 10x better when I started to offline solve.
And about 100x faster and better when I switched to ASTAP.
Now it solves in 1-5 seconds. Only got it to work 2 weeks ago.
But credit where credit is due.
I started to use the scheduler more regularly. And now I'm enjoying pretty much fully automated evenings.
The first night I play around and frame my shot in K-Stars. Copy the coordinates into the scheduler, do my polar alignment and run the sequence.
On the rest of the nights I basically only remove my dust cap and watch the images come in.
Edited by RemcoNL, 09 August 2020 - 12:16 PM.
#31 RemcoNL
RemcoNL
Posted 09 August 2020 - 12:15 PM
I absolutely hate when that happens.
Whenever it really fails to solve any target, I park my mount and delete the mount model. Then unpark and try again. Most of the times i can get it to work that way. Allthough, I havent had the issue recently.
#32 endlessky
endlessky
  • Loc: Padova, Italy
Posted 09 August 2020 - 12:40 PM
I had to troubleshoot a little, too, in order to get plate-solving to work. Some things come to mind:
- do it offline, much faster, doesn't need to rely on an internet connection
- download all the appropriate indexes for your focal length and sensor dimension combinations
- make sure before you launch a plate-solve, that the focal length in the telescope tab of EKOS matches the focal length of the telescope/lens you are using
I got it working pretty much 100% of the time after doing the above.
As far as everything needs to be plugged in, I made different profiles (with appropriate names), if I need to only test one piece of equipment, independently of the other ones (example, mount only, DSLR only, etc.). This way you can troubleshoot and save the appropriate settings of each piece of equipment, before you launch everything together.
Edited by endlessky, 09 August 2020 - 12:40 PM.
  • RemcoNL likes this
#33 Bc0428
Bc0428
Posted 09 August 2020 - 09:36 PM
#34 wxcloud
wxcloud
  • Loc: Denver, Co
Posted 13 August 2020 - 04:06 PM
I do the on line solver. Will try to switch to offline. Guess I need to plug everything in to get to that menu to change the solver location.
Can get the basics and an image out of the system and before I upgraded my OS I could auto guide :)
Edit:
I keep forgetting about wiki pages. I think I found the offline stuff. However using multiple set ups, I guess I need to figure out my various possible field of views? Probably won't mess with things for the moment, not awake enough to tinker
Edited by wxcloud, 13 August 2020 - 04:55 PM.
