Skywatcher AZ-EQ5 GT
1 reply to this topic
#1 Cydonia76
Cydonia76
  • Loc: Sydney
Posted 08 August 2020 - 05:26 AM
I’m looking at getting one of these mount for my C8, the version with the standard tripod.
Can anyone advise how well it works? Tracking accuracy, pointing accuracy, and what are vibrations like and how bad is back lash
im also thinking of the iOptron AZMount PRO., has anyone tried both?
80% of my use will be for visual use with high power planetary and planetary imaging .
it would be nice to have the option to convert to EQ and dabble with some longer exposures, but if the iOptron is a much better Mount then I’d rat
her go with that.
does the alignment procedure allow to align on Planets or the moon?
Any comment will be much appreciated
Edited by Cydonia76, 08 August 2020 - 05:32 AM.
#2 Phil Sherman
Phil Sherman
  • Loc: Cleveland, Ohio
Posted 08 August 2020 - 01:25 PM
You can't accurately align on the moon because it's an extended target and almost impossible to locate the exact center of the moon. Planets can be used for alignment but are almost always not as accurate as stars because their positions are always calculated. Planets closer to the sun than Uranus are also not points but are small extended objects.
A two star alignment takes only a couple of minutes and is much more accurate than using planets or the Moon.
  • RossW likes this
