Older XT8, do any replacement focusers match screw mounting?
1 reply to this topic
#1 phillip
phillip
  • Loc: Sterling, Illinois
Posted 09 August 2020 - 06:03 AM
Thanks in advance.
Friend has my old XT8 and notices sloppy focuser movements, recall many replace it.
Just curious if the newer improved focuses match same screw spacings??
Best
BEST
CLEAR SKY
#2 Jon Isaacs
Posted 09 August 2020 - 06:19 AM
Thanks in advance.
Best
BEST
CLEAR SKY
It depends on the model of the XT-8.  Some had 2 inch focusers and the scopes were manufactured by GSO so a GSO focuser will likely fit.
If it has a rack and pinion, it's possible/likely Orion single speed Crayford may fit.  These are often available used.
https://www.telescop...ser/p/13039.uts
If it is a rack and pinion, it can likely be improved by disassembling it and adjusting it...
https://www.cloudyni...d/#entry4616865
