ES 12" Truss Dob secondary removal?
3 replies to this topic
#1 bthrel
bthrel
  • Loc: Linden TN
Posted 09 August 2020 - 06:30 AM
Need to clean the secondary on my ES 12" dob. To remove it do you just hold on to the secondary on the sides and unscrew the 3 knobs? Anything else fall out when you do this like springs I assume?.. Also putting back I any measurement I need to take to get it back close to the original position?
Brian
#2 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 09 August 2020 - 11:12 AM
Need to clean the secondary on my ES 12" dob. (1)To remove it do you just hold on to the secondary on the sides and unscrew the 3 knobs? (2)Anything else fall out when you do this like springs I assume?.. (3)Also putting back I any measurement I need to take to get it back close to the original position?
Brian
(1)yes.
(2)yes, so watch where the springs go and make sure they don't get lost.
(3)measure the gap between the plate attached to the secondary and the plate pinching the spider blades.  When you put it back, start there.
This technique works fine:
https://www.youtube....h?v=9Y8xFnXFVGQ
Edited by Starman1, 09 August 2020 - 11:13 AM.
#3 bthrel
bthrel
  • Loc: Linden TN
Posted 09 August 2020 - 04:32 PM
Thanks Don,
Exactly how I was going to do it except with a final rinse of distilled water to help with no water drop drying spots ( I hope)
#4 Starman1
Starman1
  • Loc: Los Angeles
Posted 09 August 2020 - 04:47 PM
Yes, always finish with a good rinsing with distilled water.
He does that in the video as well.
As to whether a hair dryer (no heat) should be used to blow off the water droplets, that's up to you.
