HEQ6 recent tracking issues
mount
1 reply to this topic
#1 donddsms
donddsms
Posted 09 August 2020 - 10:58 AM
my mount tracks and guides fine for a few frames but then slews a few degrees away.  I'm stumped!
Any ideas?  thanks in advance
#2 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 10 August 2020 - 11:39 PM
For the mount, the first things to check are the power supply and the firmware.  If the power supply does not put out at least 12 volts (as measured with a meter), or even better 13 volts, then your mount will do all kinds of odd things.  If the power supply is not capable of at least 3 amps, then the same odd problems can happen.  If the power tests out, then you may need to trying resetting the firmware to the factory defaults and/or flashing/updating the firmware to ensure that it hasn't developed a glitch.
After the mount, you need to take a look at the guiding systems to makes sure that you are not having a cable or other problem that are causing it to glitch.
Also tagged with one or more of these keywords: mount
