Meade Eclipseview 114 (lightbridge mini 114).
2 replies to this topic
#1 HNunez
HNunez
Posted 10 August 2020 - 04:46 PM
Hello group,
Does anyone has experience in the Meade Eclipseview 114 (which I believe is the same as the lightbridge mini sans the moon filter)? If so, would it make a good beginners telescope?
P.D. Portability is a must :)
HN
Edited by HNunez, 10 August 2020 - 04:48 PM.
#2 Phil Sherman
Phil Sherman
  • Loc: Cleveland, Ohio
Posted 11 August 2020 - 01:04 PM
From the manual for them, the tabletop versions should work fairly well as wide field instruments. The short focal length should force a parabolic mirror which is much better than the usual spherical primary with a 2x barlow built into the focuser tube. The fast focal ratio will make colimation critical. This should be a very good lightweight portable instrument.
  • HNunez likes this
#3 Tony Flanders
Tony Flanders
  • Loc: Cambridge, MA, USA
Posted 11 August 2020 - 02:03 PM
Yes, the Eclipseview 114 does indeed appear to be the Lightbridge Mini 114 plus a solar filter.
I reviewed the Lightbridge Mini 114 favorably for Sky & Telescope. The optical tube is similar (maybe identical?) to the tube of the venerable Orion 4.5-inch StarBlast, but the mount is distinctly smaller and lighter. That cuts both ways. On the one hand, the StarBlast mount is just a bit too big to fit on a standard chair, which otherwise makes an excellent support for these scopes. (A backless chair is even better.) On the other hand, the Lightbridge Mini mount vibrates more, and it has a problem on the vertical axis that the tightening bolt tends to self-tighten and/or self-loosen as the scope moves up and down.
All in all, the various 130-mm f/5 tabletop Dobs give you distinctly more power for just a little more money, with surpringly little loss in portability. The AWB OneSky tube, when folded up, is just about the same size as the Mini 114 tube.
