Is there a way to hook up a DSLR to a mosaic'ing capture program (like SGP) and write the RA/DEC into the image metadata?
E.g. as Lat/Long is fine, or any extended metadata.
Posted 11 August 2020 - 05:53 AM
Posted 11 August 2020 - 06:44 AM
When you save the data in FITS format instead of the proprietary raw format (e.g. Canon's CR2 or CR3, Nikon's NEF, Sony's ARW or Fujifilm's RAF format), the capturing program will write the metadata (including object coordinates) to the FITS header.
Bernd
Posted 11 August 2020 - 06:51 AM
Bernd
How do I get a DSLR to save in FITS?
Though, that doesn't actually help me even if I knew how. I need to write the metadata into the Camera Raw format (or XMP).
Posted 11 August 2020 - 08:37 AM
Assuming your DSLR is supported (Canon/Nikon) SGP it will do what you wish if you've set your location in the user profile.
Posted 11 August 2020 - 11:46 AM
Posted 11 August 2020 - 12:56 PM
Whoops my bad on that part. The RA/DEC will be in the FITS header.
Here is what SGP puts in the header with images taken with my Canon T7i:
SIMPLE = T / file does conform to FITS standard
BITPIX = 16 / number of bits per data pixel
NAXIS = 2 / number of data axes
NAXIS1 = 6288 / length of data axis 1
NAXIS2 = 4056 / length of data axis 2
BZERO = 32768 / offset and data range to that of unsigned short
BSCALE = 1.0000000000000000 / default scaling factor
CRPIX1 = 3144 / reference spectrum pixel coordinate for axis 1
CRPIX2 = 2028 / reference spectrum pixel coordinate for axis 2
CTYPE1 = 'RA---TAN' / standard system and projection
CTYPE2 = 'DEC--TAN' / standard system and projection
OBJECT = 'RS UMi ' / Object name
DATE-LOC = '2019-06-26T23:31:33' / Local observation date
DATE-OBS = '2019-06-27T04:31:33' / UTC observation date
IMAGETYP = 'LIGHT ' / Type of frame
CREATOR = 'Sequence Generator Pro v3.1.0.198' / Capture software
INSTRUME = 'Canon EOS Rebel T7i' / Instrument name
EXPOSURE = 15 / Exposure time in seconds
CCD-TEMP = 23 / Camera cooler temperature
ISO = 400 / Camera ISO
XBINNING = 1 / Camera X Bin
CCDXBIN = 1 / Camera X Bin
YBINNING = 1 / Camera Y Bin
CCDYBIN = 1 / Camera Y Bin
TELESCOP = 'SynScanMobile Telescope' / Telescope name
RA = 237.718134215362 / Object Right Ascension in degrees
DEC = 72.2094521028717 / Object Declination in degrees
CRVAL1 = 237.718134215362 / RA at image center in degrees
CRVAL2 = 72.2094521028717 / DEC at image center in degrees
OBJCTRA = '15 50 52.352' / Object Right Ascension in hms
OBJCTDEC = '+72 12 34.028' / Object Declination in degrees
AIRMASS = 1.21111775660127 / Average airmass
OBJCTALT = 55.6533683311185 / Altitude of the object
CENTALT = 55.6533683311185 / Altitude of the object
FLIPPED = F / Is image flipped
ANGLE = 55.56 / Image angle
SCALE = 2.56118 / Image scale (arcsec / pixel)
PIXSCALE = 2.56118 / Image scale (arcsec / pixel)
INPUTFMT = 'FITS ' / Format of file from which image was read
Posted 11 August 2020 - 02:18 PM
Posted 11 August 2020 - 02:30 PM
A Canon RAW file named by the camera is typically something like this: IMG_0762.CR2
A fits saved by SGP has a wide range of user selected options. See page 83 of the manual found here.
The choice of RAW, FITS or both is chosen from a drop down list in camera options.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
