CGEM
4 replies to this topic
#1 wombat286
wombat286
  • Loc: So. Virginia
Posted 12 August 2020 - 03:32 PM
I have a CGEM-800, is there a adapter that will allow me to take the OTA off and just mount my camera to the saddle after going through alignment routine? Or is this even advisable?
#2 Nemesis_318
Nemesis_318
  • Loc: Michigan
Posted 12 August 2020 - 04:46 PM
The only problem you may run into is balancing the mount.  I have the same mount and encountered this very problem.  The counterweights are too heavy.   If you mount a lightweight camera like a Canon Rebel and lightweight lens it might work fine with no counterweight.  The other option is to piggyback the camera on top of your C8.
#3 wombat286
wombat286
  • Loc: So. Virginia
Posted 13 August 2020 - 09:55 AM
Yeah thought about the piggyback option, was thinking the mount might do better with just DSLR on it. Piggyback would be less trouble than taking the OTA off.
#4 TL2101
TL2101
  • Loc: Northern California
Posted 13 August 2020 - 05:16 PM
I mount my camera directly to my CGEM mount attached to a AT60ed refractor. I recently upgraded my DSLR and mount it with a 500mm camera lens attached. I tried to piggyback it on my C8 but it puts too much stress on the mount. I had the motors slip once so I no longer piggyback the camera with the refractor or a large heavy lens. It would work fine with a smaller lens.
I use a ADM D2V Losmandy Dovetail Adapter (purchased at OPT) to convert from a D series mount to a V series mount. I attach a Astro-Tech 7" short universal vixen style plate (purchased at Astronomics) to my camera lens. That way I can switch between my CGEM and Vixen style mounts.
Here is a photo of the setup. I use the lighter counter weights from my CG-4 mount to get it to balance.
Edited by TL2101, 13 August 2020 - 09:46 PM.
#5 Michael Covington
Michael Covington
    Author
  • Loc: Athens, Georgia, USA
Posted 13 August 2020 - 09:40 PM
iOptron makes some small counterweights that fit the CGEM.  Check the shaft diameter since iOptron has several different size shafts.
When using a camera and telephoto lens on my CGEM or AVX, I do the alignment with the camera!  No need to put the telescope on to align.  The grid on the camera's screen in Live View is accurate enough.  (There are menu settings on Nikon and Canon DSLRs to turn on the grid.)
