Collecting data over multiple nights with Newton telescopes.
2 replies to this topic
#1 Ckenteris
Ckenteris
  • Loc: Germany
Posted 13 August 2020 - 01:56 AM
I recently had my first "perfect" imaging night. Complete with auto meridian flip, almost no technical hiccups and my best image so far as result.
My first iteration of Elephants Trunk:
2,5h from Bortle 5 skies.
Elephant's Trunk
Now on my topic. I am thinking about adding more data. If my thoughts are correct, the relative position of the object will change over time. So two images taken some weeks apart with identical framing will have different spikes. Which leads to the problem of reacquiring the exact position of the diffraction spikes when framing the object, especially after a longer break.
The only way of countering this would be rotating the telescope tube itself accordingly.
Are my assumptions correct?
If I would do this. Is there a way, to overlay my existing data while framing to fine tune my image? (I am using NINA for imaging, and Sharp Cap for PA, did I overlook something here?)
Thank you for your time,
Andreas
#2 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 13 August 2020 - 07:19 AM
Since you're using an equatorial mount, the scope rotates along with the sky.  So, unless you change the orientation of the tube relative to the mount, then the spikes should be in the same place.
-Dan
  • ChrisWhite, ks__observer and colinrm like this
#3 ChrisWhite
ChrisWhite
  • Loc: Colchester, VT
Posted 13 August 2020 - 10:38 AM
-Dan
Yep, no worries at all.
