CEM70g connection to SkySafari Pro
5 replies to this topic
#1 bec
bec
Posted 14 August 2020 - 12:30 AM
Hello
Just read that CEM70/70g do not have an RS232 port.  I have 70g on order and am wondering how to hook up SkySafari Pro 6 which is loaded on my Ipad to the mount?  My adapter is the SkyFi-USB Adapter.  I read that plugging into usb on cem70 picks it up as an rs232 port????   I have this setup on my CEM60 and all works great.  If you have either one of these mounts and are using SS let me know.  Thanks in advance
bec
#2 eros312
eros312
  • Loc: Tampa, FL
Posted 14 August 2020 - 01:22 AM
70g has built in wifi, you don't need the skyfi.
Edited by eros312, 14 August 2020 - 01:25 AM.
  • bec likes this
#3 bec
bec
Posted 14 August 2020 - 09:49 AM
Thanks for response.  So do I just setup 70g wifi and click on SS on my Ipad?
bec
#4 eros312
eros312
  • Loc: Tampa, FL
Posted 14 August 2020 - 10:05 AM
I don't know the exact procedure, I have the GEM45 and the skyfi for it. Probably whatever worked for your cem60 and skyfi. Just connect your iPad to the cem70 wireless and it should work.
#5 bec
bec
Posted 15 August 2020 - 04:54 PM
My CEM60 has the rs232 port on the mount and that is how I connect to run SS.  You say you have the skyfi,,,is it plugged into a port on your mount or do you connect elsewhere?  Maybe I am missing something in the hookup,,or over thinking it.   Just don't want a new mount (without rs232 port)  with no way of running SS or asiair pro.
bec
#6 bec
bec
Posted 17 August 2020 - 11:11 AM
Hello,,,thanks for your input,,,,it finally sank in how this all works,,,,,I thought the actual skifi adapter did more than it actually does,,,,now I realize it just creates the wifi bubble,,,,but now realize that the 70g mount does the same thing,,,,thanks again
bec
  • eros312 likes this
