Dove Tail plate
2 replies to this topic
#1 nzch
nzch
Posted 14 August 2020 - 02:30 AM
Hi All,
Stupid question i know ha.
What are the slots on the dove plate for? Will these fit 90mm Tube rings somehow? I don't think the William optics 90mm rings have the correct spacing for the threaded holes.
I'm tying to make the two work (see images).
Any advice would be appreciated.
Jake
#2 DLuders
DLuders
  • Loc: Spokane, WA
Posted 14 August 2020 - 03:46 AM
Some manufacturers of Tube Rings have a single screw that attaches to the dovetail plate, like this 90mm Orion Tube Ring set.   smile.gif
#3 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 14 August 2020 - 10:45 AM
You can't thread a bolt through the dovetail AND into the rings. The threads would not be aligned right.
You put two bolts through two holes at one end of the dovetail and into a ring.  Then (typically, depending on your scope) at the other end of the dovetail you put two bolts through 2 slots in the dovetail and into the other ring.  Having one ring mounted on a slot lets you adjust the ring spacing.
That is an unusually thick dovetail you have shown. What is with that?
Edited by t-ara-fan, 14 August 2020 - 10:46 AM.
