Televue NP101is backfocus spec
2 replies to this topic
#1 Donnie D
Donnie D
  • Loc: Madison, Mississippi
Posted 14 August 2020 - 11:30 PM
Does anyone know what the Backfocus is on the Televue NP101is?  I have read the manual for the NP101is , plus other reading, and I have derived at some numbers for back focus. I am not sure my values are correct.
Thank you kindly
Donald
Edited by Donnie D, 15 August 2020 - 01:02 AM.
#2 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 15 August 2020 - 01:14 AM
There is no "backfocus spec" for the is series of scopes. Just focus it as you would any other refractor. If you are using a focal reducer or a flattener that's another matter but otherwise there is no "sweet spot".
Rgrds-Ross
#3 Donnie D
Donnie D
Posted 15 August 2020 - 01:25 AM
Thank you Ross, I was wondering about that.
I found out so far that if you use a reducer/flattener then the reducer/flattener will have  an optimum 55mm back focus. (Distance from flange surface to film or CCD plane). If you use a CCD, be sure the spacing between flange and CCD is 56mm +/-2mm for best results
Edited by Donnie D, 15 August 2020 - 01:26 AM.
