William Optics Rotolock visual back -- won't unlock.
accessories
2 replies to this topic
#1 Poe
Poe
  • Loc: Utah
Posted 15 August 2020 - 02:15 PM
Hey there friends, I hamfisted my William Optics rotolock down too tight in a panic after a kiddo tried to use the diagonal as the top rung of the stepladder. Yes, a C-14 on a CGE Pro is tall, but they are not jungle-gyms kids!
I didn't realize that it was the tiny set screw (1.5mm allen) at the joint came not full tightened, so what was actually spinning was not the diagonal in the lock the but join on the visual back itself. Anyway, like a dummy, I over-tightened the rotolock mechanism around the diagonal instead. Somehow I managed to get the diagonal back out, but I still can't get the Rotolock to release, even when using all the extra force of having 2 guys, turn soft-mouth clamps in the opposite direction!
I also pulled out the allen set screw on the top of the gold colored ring (you can see it there perched on the end of the allen wrench) and found a spring and a ball bearing underneath. Regardless of having that in or out of the device, or even at different tightness, I still can get the lock to release under an amazing amount of force -- the amount of force you would expect would break pretty much anything made of aluminum.
So, I'm curious if anybody has made this mistake and figure out how to fix it?
In the meantime I might try the Baader clicklock visual back, but I do like color of the William's Optics rotolock as it's pretty close the Celestron orange that I love so much.
#2 Xeroid
Xeroid
  • Loc: USA
Posted 15 August 2020 - 02:30 PM
OK, since you asked, how about this:
Place it in the freezer for 1 hour then take it out and then direct heat from a hair dryer to the gold color ring?
  • Poe likes this
#3 Xeroid
Xeroid
  • Loc: USA
Posted 15 August 2020 - 02:31 PM
Or get some PB Blaster from Home Depot and soak it*...
Edited by Xeroid, 15 August 2020 - 02:48 PM.
Also tagged with one or more of these keywords: accessories
