Sky Designs 17.5" First Light & Questions
27 replies to this topic
#26 JimV
JimV
Posted 03 September 2020 - 07:54 PM
You have to push and pull everything to see what is loose.  I had a similar problem, and it was a wiggly board that held focuser.
Could be a problem with secondary mount or spider.  Could be poles slipping.
Laser collimator is useful.  Get a 2" one.
#27 Daveatvt01
Daveatvt01
Posted 14 November 2020 - 06:15 PM
It’s been a while since I last posted about this, but the scope is coming along! I dropped the collimation bolts back down to a normal height and cut the truss tubes down by about 1/2”. Then I used plastic to make a replacement cell and made mirror clips out of wood that look similar to the original ones:
New clips and cell
Some anti-slip tape on the UTA a where the truss poles connect seems to have stopped the shifting too.
I’m holding off on fans until I decide for sure if I want to try to separate the mirror from the wooden circle it’s adhered to...
#28 Daveatvt01
Daveatvt01
Posted 11 February 2021 - 04:29 PM
I finally got around to installing some fans! I put a bank of three on one side pulling air in, and two on the other side pushing air out.
Drilling and cutting
Fans
New fans!
