I don't use Reflectix. This is only one material that can be used to make insulation wraps.
I make my insulation wraps out of Coreflute. And I have also made insulation wraps out of light coloured EVA foam yoga mats. What is critical here is not the material as such, but that the material actually provides an insulation property. We are not using these materials for what they have been originally designed for so you cannot be so stuck in "technical properties" because we are not using them in a house as we would for Reflectix. EVA/Neoprene has excellent insulation properties, which is why it is used in wetsuits. Coreflute is typically used to make signs, but it too has excellent insulation properties for our scopes.
What is important here is the colour of the material. DON'T use black or other dark colours. This has a major impact on how it reacts to temperatures are night and it will cool to a lower temp than ambient, attracting dew long before lighter colours as well as altering the insulation/thermal properties we seek from the insulation wraps.
Below are three pics, one showing the C8 I had with the yoga mat wrap I made for it (the insulation wrap only needs to cover 2/3 of the tube to be effective) and my 9" Mak with its Coreflute wrap. The third shows the wrap I made for my 127mm Mak with its war-paint livery to stir up the neighbours...
. The forth pic shows how tightly these wraps can be rolled up for storage.
Coreflute does take more care and time to turn into a wrap (every second cell is cut down its entire length in order for it to adapt to the tight radius of the OTA), but it can be easily designed and made to fit around the various "bits" that hang off on OTA and is the most robust material that easily handles the installation and removal every session. In the pics of the Coreflute wraps you can see how each wrap has been cut to fit around different bits on the OTA, such as finderscope shoes and handles.
One BIG advantage of a Coreflute wrap is it can be easily made to have small fans fitted to its dewshield section as a means of dew control WITHOUT heat. Very effective, far more efficient, way less power and no thermal compromising of the corrector or OTA. Vibrations? Fans have been used for YEARS with other scope designs and you never hear anything about vibrations, so no vibrations. I started a thread about this:
CN link -> Dew-free SCT's and Maks WITHOUT heat - it is possible. Refractors too.
NOTE: there are other spin off benefits to making a wrap for your scope, even if you don't believe in the insulation aspect:
* These wraps will extend the dew-free period for the corrector. Depending on the design of the wrap and conditions of any given night it may be enough to keep the corrector dry all night long when on other nights it would have dewed over.
* Protects the OTA from getting wet and prevents this water from finding its way into the various nooks and crannies that scopes have - THIS is the water that is most difficult to have dry off out of the scope, NOT what you think that you can see that has dried off.
* Making the wrap removeable also helps with the drying off and long term preservation of the scope. It is not a good idea to keep the wrap permanently fitted to the scope - it works against the advantage of keeping dew off the scope in the first place.
Alex.
Edited by maroubra_boy, 19 July 2023 - 06:09 PM.
