Perhaps true to the nature of an older medium, I finally have some thoughts to share after a fair amount of time has passed between my receipt of various roles of film and the point at which I could actually look at the results. If anything, this has definitely been an exercise in mustering patience, and it's been a reminder of why film saw itself being superseded by digital photography.
First, here's my setup: a Praktina FX camera body attached to my 1962 Questar #2-14xx:
Having a waist level finder was invaluable for achieving (or trying to achieve) focus when the camera was attached to the scope.
I started out with four rolls of film of various ISO speeds: Kentmere 400, Fomapan 200, Fomapan 100, and Rollei RPX 25, all ordered from Blue Moon Camera and Machine in Portland, Oregon.
To make a long story short, I exposed all four rolls shooting various subjects both day and night at various shutter speeds. My objective at this point was to get a feel for each ISO and what exposures were best under what conditions. I kept careful notes of each exposure (equipment used, subject, light conditions, etc.).
Much to my dismay, I ended up losing my role of ISO 100 film. I was just finishing up the roll of film, and I tried to advance it to the next frame. But as I did so, I suddenly felt a bit of give in the resistance to turning the film advance knob, and then I heard film flapping about inside the camera. The film tore right off of its spool inside the canister. At first, my mind searched for a solution, but I realized that there was no getting the film back into the canister, so I simply popped the camera body open and saw my now ruined roll detached from its canister. Bummer.
Since this was my very first time that I ran film through this camera, I wanted to see if there were any light leaks, so I opted simply to get the film developed without getting any prints made. A neighbor of mine happens to have a film scanner that he lent me, and using that device save me a fairly substantial chunk of money in terms of having to get prints made. Besides, I simply needed to see how my exposures turned out.
I'm really glad that I avoided getting those prints done, because I found that most of my photos were badly underexposed. Looking back at my notes, I see that I tended towards 1/100th-second exposures and faster when I should have been tending more towards 1/10th- or 1/25th-second exposures.
Focus was also quite a challenge. My waist level finder worked great when the camera was attached to my Questar and aimed at the Moon, but my lunar photos still turned out disappointingly fuzzy. Seeing that gave me a newfound respect for the lunar astrophotography work of the Davises that Questar used in its advertising all those years. For daytime work, I found that I needed a split-screen finder when using the camera with its own lens. I actually do have another Praktina FX with a non-functional shutter, split-screen finder, and pentaprism, but at the time I was too lazy to switch out parts between my non-functional and functional Praktinas.
Here are the best two lunar photographs I was able to get. I had my Praktina FX closely coupled with my Questar (no extension tubes). Both photos are unaltered except for cropping and file size reduction.
Kentmere 400, 1/50th sec exposure, August 23, 2020, 8:30 pm:
Fomapan 200, 1/25th sec exposure, August 24, 2020, 8:37 pm:
Both nights, there was some smoke haze in the sky from wildfires in the region.
I'm fortunate to have another Questar, #2-15xx, which went through a wide-field conversion at some point in its life as has that larger-diameter axial port. My #2-14xx has its original narrow-field construction and smaller axial port intact. Here's a comparison of the two. Both photos were taken with Kentmere 400 at 1/500th second exposure.
First, #2-14xx and its narrow-field construction:
And #2-15xx and its wide-field construction (and failed coatings, which may explain the somewhat darker appearance):
Note how much vignetting is going on with the older narrow-field standard. I now have a better understanding of why Questar brought about the wide-field construction in 1964.
One of the more exciting moments of my experimentation was when I was using my scope and camera to capture this nearby bush. I noticed a hummingbird fly around and managed to capture several exposures at various speeds when its perched itself and settled down. Here is the best photo, heavily doctored because it was the least underexposed of the photos I took all of which were badly underexposed:
I happened to have my cell phone on hand, and I snapped this photo with its camera aimed into my waist-level finder:
The hummingbird was maybe 40 feet away or so.
The irony is not lost on me that I got my best hummingbird photo my aiming a cell phone camera into the finder of my film camera while it was attached to my Questar.
Lessons learned: I'm wondering to myself whether I want to continue down the film route. Clearly, I need to work on my focusing. I need to make my exposures using a slower shutter speed. And the interminable wait between making exposures, sending the film off for processing, and waiting some more to get my negatives back, not to mention having to pay for processing when I know that digital is immediate and free (once you have the camera, of course) are all factors that, frankly, put me off a bit.
As Terra noted, I could invest in my own film developing setup and use something like my neighbor's film scanner.
But I'm tending towards loosening the purse strings and getting that Canon M200 mirrorless camera I've wanted for a while. Now that I have at least some experience with film, I may branch out and trying out the digital route with my Questar, which I've never done because of a lack of a proper camera with removable lens.
