1.25" Thread-on Eyepiece Holders for Classic Refractors
66 replies to this topic
#51 Chuck Hards
Chuck Hards
Posted 27 October 2020 - 02:07 PM
Last month I found this combination that works great on Asahi Pentax 60mm and Asahi Jupiter 60mm scopes, apologies for the delay in posting.   1.25" adapter from SVBONY with a 42mm thread, then a 42mm-37mm step ring, then right onto the focuser barrel.
Again, only a couple of threads holding the step rings in place, so I'm not using a heavy diagonal or eyepiece.  But it works great with a light payload.  Non-marring setscrew is nice on the SVBONY.
  • Pete W, Bomber Bob, walter a and 4 others like this
#52 Kasmos
Kasmos
  • Loc: So Cal
Posted 27 October 2020 - 02:18 PM
Beautiful
  • Chuck Hards and Van Do9:3 like this
#53 Jaz5833
Jaz5833
  • Loc: San Diego, California
Posted 17 November 2020 - 01:05 AM
Will the Vixen, or others, work on the 6339?
#54 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 17 November 2020 - 08:22 AM
Mine should arrive this week. I didn't buy it for my 6339 but I'll try it an let you know. AFAIK they don't usually fit.
#55 CharlieB
CharlieB
  • Loc: Southern NH
Posted 17 November 2020 - 09:39 AM
No. They only work directly with single drawtube scope.  The 6339 has a double drawtube.
Charlie
  • Jaz5833 likes this
#56 Pete W
Pete W
  • Loc: Hutto, TX
Posted 18 November 2020 - 09:33 AM
The Vixen visual back will not thread onto the pull-out tube of the 6339a or Tasco 10TE, but if you remove pull-out tube the Vixen will thread onto the larger diameter draw tube that has the focuser rack on it.
The top pic shows the Sears 6339a with a 30 to 42mm step-up ring and male-threaded visual back on the pull-out tube, just like Chuck's set-up in his most previous post.  The bottom shows the Tasco 10TE with the pull-out tube and black knurled ring removed.  Two 36.4mm thread-on extension tubes along with the Vixen 36.4mm visual back are threaded onto the larger diameter focuser tube.  This still needs another slip-in extension tube for the scope to reach focus.
  • Bomber Bob and Garyth64 like this
#57 AndresEsteban
AndresEsteban
  • Loc: Rio de Janeiro, Brazil
Posted 02 December 2020 - 11:50 AM
Another solution is to pick up a 0.965" to 1.25" adapter, cut the 0.965" and machine a new 36.4 mm thread on the 1.25" holder. This apporach has the advantage of a low length (13mm) profile coming out of the drawtube and almost the same internal length for the 1.25" ep barrel (25 mm) with a compression ring..
1.25" eyepiece - focuser adapter for vintage refractors with 0.965" original ep
1.25" adapter for vintage refractors
1.25" eyepiece - focuser adapter for vinatge refractors
MILO (SYW) 60mm f/13 vintage refractor
76.2mm (3-in) f/16 Dean Beam (OKKK), vintage refractor
Clear skies for us all!
Andy
  • Pete W, mdowns, Bomber Bob and 1 other like this
#58 MisterDan
MisterDan
  • Loc: Colorado
Posted 02 December 2020 - 12:35 PM
That's an excellent idea, Andy, and a great example of thinking "outside the box," as they say.  Did you increase (ream) the bore of the adapter, as well, or did your initial cut eliminate the smaller diameter?
Best wishes, and thanks for sharing.
Dan
Edited by MisterDan, 02 December 2020 - 12:37 PM.
  • AndresEsteban likes this
#59 AndresEsteban
AndresEsteban
Posted 02 December 2020 - 06:06 PM
Dan
Dan, the guy from the mechanical workshop just cut the  main 1.25" body about (40 mm OD)  1 mm above its end (see the Fig 1, the removed 0.965" part it's painted in green). What was left is a 1.25", 40 mm OD cilinder (filled in blue color). Then using the lathe que reduced the external diameter, 40 mm OD, to something a little bit around 37 mmalong 10-11 mm in length. Then the 36.4 thread was done leaving 13 mm of the original 1.25", 40 mm OD body (blue cilinder). Now the finished piece is shown in Figure 2, filled in red color.
Figure 1
esquema
Figure 2
adaptador tubo para 1.25 polegadas
Andy
  • Bomber Bob, MisterDan and Kasmos like this
#60 Beastmaster
Beastmaster
Posted 02 December 2020 - 11:42 PM
Where does one get 36.4mm thread on extension tubes?  I have one that came with one of my Mayflowers, but I need extra length.  Any good, current sources?
  • Pete W likes this
#61 Pete W
Pete W
  • Loc: Hutto, TX
Posted 03 December 2020 - 12:26 PM
Fred, I've only been able to pick one up in the used equipment market.  Vixen used to make them but I think they've been discontinued.   I could not find a source of new thread-on tubes.  One of the more experienced scope collectors/restorers here on CN may have other options or sources.
#62 Defenderslideguitar
Defenderslideguitar
  • Loc: Connecticut
Posted 03 December 2020 - 12:43 PM
Posted 31 August 2020 - 06:49 PM
possibly another source ? 21,99   free shipping
https://www.ebay.com...353.m2749.l2649
I posted the above the last day of August       it was estimated to arrive in late November  I am hopeful it will get here soon
I had one already for use on my Mayflower 814    but I switched it over to the 1958 Tasco 10te  and ordered this other one to have two...…..Seller is still listing them   and shipping is now faster   estimated for January
#63 Beastmaster
Beastmaster
Posted 03 December 2020 - 01:53 PM
Thanks - I have one of those - I'm thinking of a 36.4mm to 36.4mm tube (female to male) extension tube.  My Mayflower (H.O.C.) came with one (see below), that doesn't quite thread in perfectly.  I need another one to get enough draw to reach focus on my Mayflower RAO with the pull draw tube.  I'm close, but just not close enough.  I think I need another one or two more.
Very elusive part.
#64 Kasmos
Kasmos
  • Loc: So Cal
Posted 03 December 2020 - 02:16 PM
Perhaps you could use a empty 1.25" barlow as an extension tube.
I believe that's what Robert was saying in post#35
 https://www.cloudyni...ors/?p=10468707
  • Bomber Bob and Beastmaster like this
#65 Pete W
Pete W
  • Loc: Hutto, TX
Posted 03 December 2020 - 03:05 PM
Yep, I've not been able find a vendor for these.  I snagged one posted on CN Classifieds a few months ago but haven't seen once since.
Very elusive part.
#66 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 03 December 2020 - 03:23 PM
Old Tele Vue 2.5x Barlow upper half works with the 30mm pull-tube / coarse focus on my Sears 6336:
  • Kasmos likes this
#67 MisterDan
MisterDan
  • Loc: Colorado
Posted 03 December 2020 - 03:43 PM
M36.4 to T2 adapters are common, as are T2 extensions.  You can switch to the T2 format and utilize a T2-to-1.25-inch visual back.
Sequence would be:  M36.4-T2 adapter + T2 extension + T2-1.25-inch visual back.  (Edit:  there are both male and female T2-to-1.25-inch visual backs.  Most of the M36.4mm-T2 adapters utilize male T2 threads, so a female T2-to-1.25-inch back may be "easier" to adapt.  Baader makes at least two such backs.)
M36.4 extensions are, indeed, hard to find, now.  I know the Tasco VR9, VR99, and VR999, each came with an M36.4 extension.  Not sure about the Celestron and/or Meade 60mm f/5s.
Best wishes and luck.
Dan
Edited by MisterDan, 03 December 2020 - 04:14 PM.
  • Terra Nova and Beastmaster like this
