Tele Vue Renaissance #1778
38 replies to this topic
#26 Peter Ceravolo
Peter Ceravolo
Posted 08 September 2020 - 05:35 AM
BlakStar I'm very happy with your old scope!
Taking it apart to buff it up makes one truly bond with the instrument!
When it's not under the stars it looks great in the living room.
Peter
Edited by Peter Ceravolo, 08 September 2020 - 05:36 AM.
  • doctordub and B l a k S t a r like this
#27 Renaissance1
Renaissance1
  • Loc: Chicago
Posted 13 September 2020 - 01:40 PM
Pier w:lens holder.jpeg
I've has mine since Halley's Comet.
  • ianatcn, Terra Nova, walter a and 3 others like this
#28 Peter Ceravolo
Peter Ceravolo
Posted 13 September 2020 - 11:22 PM
I like your "I don't need no star diagonal" set up.
What's been your experience with the tube finish over the years? I was curious how the brass fared with time so I searched the web for samples, here is one that is  a little worse for patina than the instrument I just acquired:
https://www.artsy.ne...sance-telescope
  • Mister T., Terra Nova and 25585 like this
#29 Compressorguy
Compressorguy
  • Loc: Clayton, NC
Posted 14 September 2020 - 06:44 AM
I’ve had mine now for about 1-1/2 years. I keep it indoors displayed on its mount in the living room corner. Eventually (6 months) the bright mirror finish becomes a little dulled and I simply wax the tube with regular carnuba paste wax and an old cotton T-shirt and it comes right back. Takes like 5 minutes. If it requires more then I’ll break out the Flitz polish and cotton T-shirt. I think the trick is not to let it become so tarnished that it takes a lot of work to bring it back. Also a little polish goes a long way. Apply a just a dab to the cloth, then wipe the scope down to avoid it running and caking under the clamp and cells, which turns white and looks bad when it dries. It really has not been a lot of upkeep at all.
  • Mister T., ianatcn, Terra Nova and 5 others like this
#30 tim53
tim53
  • Loc: Highland Park, CA
Posted 14 September 2020 - 11:34 AM
Back when I used to wash and hand wax my own cars, I learned of a trick to clean off the wax in grooves and under weatherstripping.  Take an old toothbrush to clean out these areas.  I used to use J-Wax "Kit" cleaner wax.  I haven't seen it in decades, so I don't know if it's still available.  It had a weak polish mixed in with the wax, which would probably not be good on modern car finishes.  But it worked great on my 1980 Westfalia.
  • Compressorguy and 25585 like this
#31 RichA
RichA
  • Loc: Toronto, Canada
Posted 14 September 2020 - 08:35 PM
Rich, my spider sense suggests that it would be easier for most to simply buff/polish and wax the tube every few years when the patina gets out of hand. A few hours effort at most.
You are absolutely right, the skills associated with spraying lacquer on brass to preserve the finish is tough to acquire, and then there is the recipe for the lacquer. A member of the ATS has gone through the process, guided by a conservator in Italy - it was a bigly job!
Yes, and it would be a pain if it got partway done and something went awry.
#32 RichA
RichA
Posted 14 September 2020 - 08:43 PM
A few months ago a Tele Vue Renaissance refractor was offered for sale by a fellow Canadian. One could tell from the photos that the brass tube had acquired some nice-looking patina. I recently became enamored with brass, I had acquired and started dissecting, documenting and restoring an antique Cooke refractor. Seeing the add I pondered the notion of modern brass. The current owner mentioned that the finish on the brass tube was not quite ideal, the original owner had tried to polish it and left some residue on the OTA. We made a deal and I had the scope shipped across the country.
The Renaissance brings back memories of very early 1980’s Stellafane. I had some one-on-one observing time with Al Nagler and his MPT and prototype Nagler eyepieces. The wide-rich-field views of the Milky Way were amazing compared the “peep hole” eyepieces I was used to. I have always been impressed with Tele Vue’s ground breaking and high-quality products, so it’s a treat to finally acquire a Tele Vue instrument of that heritage to use with the dozen or more Tele Vue eyepieces I have accumulated over my four and half decades doing astronomy.
Here is the Renaissance mounted on a Losmandy 200 for testing.
As soon as I could, I spent some time with the telescope under the stars on nights of good seeing. Although the collimation was a bit off, I was impressed with the image quality, a clean Airy disc and diffraction rings at 344x. That high power is achieved with a 8mm Radian and 5x Powermate. What struck me the most was the color correction; it was much better than I was expecting. I must admit I am not a refractor aficionado, with talk of the number of crossings etc, but I don’t see much difference in the Renaissance’s faint blue halo when compared to my Stellarvue 110mm f/7 ED’s faint blue halo. There is perhaps a bit more spurious red in the Renaissance image. David Nagler says that the 4” f/5.5 Renaissance has the color correction of a 4” f/8 achromat.
David tells me that the Tele Vue Renaissance #1778 was born April 12, 1993 and was the 5th from the last one made. Upon opening the case I saw that the black anodized cell and end ring had faded from exposure to the sun. The brass patina was blotchier than expected and the polish residue was a lot more obvious than I would like in instrument that I would want to display as much as use. Some might be annoyed - I saw an opportunity - let’s rip the scope apart and see what’s inside while we clean it up!
Most to least colour that I've seen in scopes I've owned:  Renaissance, Genesis, Genesis SDF, TeleVue 85, Meade 102ED, AP Traveler, Takahashi FS-102.
#33 25585
25585
Posted 31 December 2020 - 11:31 AM
These are my 102 & 85 Renaissances, as bought.
  • tim53, ianatcn, Terra Nova and 3 others like this
#34 RichA
RichA
Posted 31 December 2020 - 03:00 PM
photos are too small to really see them.
#35 Terra Nova
Terra Nova
  • Loc: 39.07°N, 229m AMSL, USA
Posted 31 March 2021 - 09:38 AM
I just picked back up on this thread where I left off last year. I loved re-reading it. Bill (Bonco2) mentioned that his Genesis is his favorites telescope. I have to second that! My Genesis SDF is my favorite. I have said for some time that if I could only keep two scopes, it would be it and my Questar Standard. They complement each other wonderfully. With just those two and my Zeiss 10x50s, I could be one very happy (astronomy) camper.
  • ianatcn and Bomber Bob like this
#36 Mister T.
Mister T.
  • Loc: Sun Prairie, Wisconsin
Posted 03 June 2021 - 08:23 AM
Also I was VERY lucky to find a TV screw on dew shield on eBay and snapped it up as soon as I saw it. I know they were offered with the very early design Genesis before the sliding dewshield but not sure they were ever offered with the Renaissance.
"VERY lucky" doesn't even begin to describe that find! Finding ANY parts for the early Rens is near impossible; even
Televue winds up scrounging them from their "bone yard" for factory repairs; I speak from experience on that!
My scope likewise had a bent focuser shaft, and it now has a factory installed substitute (not brass plated).
My Renaissance was also purchased without the dew shield, and for the past 3 or 4 years I've been searching for one.
I'm pleased to say that in the past 24 hours I've FINALLY found one, courtesy of another CN member!  laugh.gif  The shield is
on it's way to me as we speak.
I also have a Genesis, with the dew shield; it fits the Renaissance, and for literally YEARS now I've been swapping it
between telescopes...  not a satisfactory situation at all.
NOW...  the NEXT item you want to watch EPay for is a Genesis clamshell. It has the cuts for a finder mount that the
Renaissance clamshell doesn't. I lucked out on that one fairly early in the game.
I'm just wondering how YOU found that dew shield before I spotted it...     bow.gif  lol.gif
  • Terra Nova and Bomber Bob like this
#37 Mister T.
Mister T.
Posted 03 June 2021 - 08:32 AM
"I had ordered "Conservator's Wax" recommended to for antiques, but I needed something now so I applied Mother's California Gold - Pure Brazilian Carnauba wax. If it's good enough for my 'vette, it's good enough for the Renaissance - at least for now... :-) "
Here's ANOTHER vote for Mother's California Gold! My Ren doesn't get anything else; that's some GOOD stuff!
#38 RichA
RichA
Posted 03 June 2021 - 07:42 PM
What someone needs to do...is get a Renaissance and detail its barrel with engraving like a high-end rifle.  smile.gif
#39 Renaissance1
Renaissance1
  • Loc: Chicago
Posted 10 January 2022 - 12:00 PM
My Renaissance is #1154--5/20/1985Pier w:lens holder.jpeg
  • Terra Nova likes this
