does this look like a normal DBE for a set of DSLR images
25 replies to this topic
#1 russellmm
russellmm
  • Loc: Gig Harbor WA
Posted 31 August 2020 - 08:15 PM
Would like some feedback if this looks like what one would expect from a Dynamic Background Extraction in Pixinsight?
For one, its clear the bottom right is either hot or overexposed in the images (I am not sure why).
going through the editing process gets rid of/ hides most of it, but I am not sure if I should expect something cleaner to begin with
I tried shooting this target (M33) both at 15 sec and 30 sec to see if the noise gets better but it seems to be about the same.
The attached is a stack of 600 images. Using a Canon 5D Mark IV (unmodded) and 300MM F2.8L lens
Regards
Russell
#2 AstroBrett
AstroBrett
Posted 31 August 2020 - 08:28 PM
Try using about one fourth as many data points. Having too many samples forces the model surface to conform to the high frequency variations, in other words, the model surface is more crumbled when it should be a relatively smooth surface.
Brett
#3 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 31 August 2020 - 08:29 PM
Nope - Have you tried ABE?  What direction is the LP coming from?  What were the DBE settings?
#4 russellmm
russellmm
Posted 31 August 2020 - 08:41 PM
I have tried using fewer points (I usually use like 10-12 per row) this was just me messing around with more points to see if I could get a different result. So same result with fewer points.
Attached is the DBE settings (I left it on one of the marks in the lower right hand corner so you could see the noise sitting on that point)
Also attached is what ABE generates. ABE does not like that hot corner at all...
That hot corner does not show up in my other images.
One issue is that M33 starts a little lower on the horizon and I am shooting it starting at around 1.3-1.4 Airmasses. I am in a Bortel 5 location but I *am* shooting towards the worst part of my light pollution, which is East.
Edited by russellmm, 31 August 2020 - 08:42 PM.
#5 russellmm
russellmm
Posted 31 August 2020 - 08:53 PM
This is what i looks like if I use just 31 points
#6 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 31 August 2020 - 09:02 PM
I never go over a tolerance of 0.750...most times I leave it a default.
I normally use just 5-10 points around the perimeter and 2-3 near the center.
But seeing all of your versions, it looks like you had a cloud parked to the right of M33 for quite awhile.
  • Paul Garais likes this
#7 russellmm
russellmm
Posted 31 August 2020 - 09:14 PM
Thanks Dave.
I reviewed all the images and scored/weighted them before including them. I did not see any variations in the images that looks like a cloud or mists of a cloud, so I don't know. I'll keep playing around with it and see if I can improve it.
Best Regards
Russell
#8 russellmm
russellmm
Posted 31 August 2020 - 10:54 PM
interestingly, if I use a radial approach to DBE, I get a much more uniform look, but there still seems to be a lot of Light Pollution glow left in the right portion of the image that makes it unusable
Edited by russellmm, 01 September 2020 - 12:45 AM.
#9 bobzeq25
bobzeq25
Posted 01 September 2020 - 01:23 AM
What we _really_ need to see is the background image.  That tells you how things are going.
I generally use about 10-15 points.  Gradients are large scale, there's nothing to be gained (and much to be lost) by using many points.  It's like setting your PhD2 exposure to 0.5, thinking that will guide better.  In both cases wider sampling intervals (time or space) usefully apply a low pass filter to the data.
#10 russellmm
russellmm
Posted 01 September 2020 - 02:02 AM
here is a DBE with fewer points selected. I boosted the background to make the Gradient easier to see. If I try to put a point in the lower right hand corner, I would have to put the tolerance way higher to make it not go red because the lower right is so blown out for some reason (the single images don't seem to show any weird gradients unique to the lower right half of the images).
#11 russellmm
russellmm
Posted 01 September 2020 - 02:05 AM
This is about as good as I can get the final image to after post processing it.
  • dswtan, bobzeq25, 2ghouls and 1 other like this
#12 Paul Garais
Paul Garais
  • Loc: Sendenhorst, Germany
Posted 01 September 2020 - 02:30 AM
I also recommend to use as few points as possible. I started with tutorials that advised to use x samples per row etc.. That is a bad practice, because it will cause checkerboard structure that is clearly visible in the background. As others said above: There is nothing to gain from more samples.
If you have a linear, straight gradient, you only need two samples.
I look at the image and try to understand where the gradients are before setting the first sample. I start with 2-3 samples and look at the gradient map DBE produces and compare it to what I try to fix. I add single samples if needed and check again.
Since I do so, I did not had a case where more than 10 samples where needed.
—Paul
#13 spereira
spereira
  • Loc: Bedford, NH
Posted 01 September 2020 - 07:10 AM
Moving to DSLR ...
smp
#14 RJF-Astro
RJF-Astro
  • Loc: Zeist, Netherlands
Posted 01 September 2020 - 07:35 AM
Definitely not bad for 4-5 hours. What f-ratio did you use? The thing with STF is that it really stretches your image. And uncooled DSLR images can look bad when stretched hard. So yes, your DBE could use some refinement but I would not overdo it.
  • russellmm likes this
#15 Madratter
Madratter
Posted 01 September 2020 - 09:03 AM
I go into ABE and DBE in some depth in my unfinished second PixInsight Tutorial. You can see the ABE section here:
https://astroimages....ion-part-1.html
The DBE section immediately follows. In general, I agree that people tend to use more points when doing DBE than is wise.
#16 russellmm
russellmm
Posted 01 September 2020 - 09:51 AM
I am using F2.8.
I have tried 15 sec exposures to try and bring down the glow/noise
Thanks for the advice all.
I'l take a look at your Tutorial Madratter.
Edited by russellmm, 01 September 2020 - 09:53 AM.
#17 fmeschia
fmeschia
  • Loc: Mountain View, CA
Posted 01 September 2020 - 10:36 AM
Regards
Russell
It seems to me that you sampled points in the galactic halo of M33, and as a result DBE overcorrected the gradient, creating a “hole” in which M33 now sits.
There’s a great free video by Adam Block that faces a similar image situation, and solves it very nicely with DBE: https://www.youtube....h?v=f6IN9cXVh-4
#18 bobzeq25
bobzeq25
Posted 01 September 2020 - 11:33 AM
That background looks correct, a nice smooth gradient.
And the final image is nice.
#19 Euripides
Euripides
  • Loc: Thessaloniki - Greece
Posted 02 September 2020 - 09:01 AM
Guys I always look first the background result of DBE or ABE and I can see the patterns. Usually I take max 20 samples and tried different settings, for example Tolerance 6, Sample Radius 100, Minimum Sample Weight 0.150.
But I can clearly see "black patches" at my final stages of post. Is this something that can be eliminated with better DBE, or it is just limitation of my gear (stock DSLR, high temps etc.)
This crop is just before my final DeNoise .
PS. Those patches are visible even in 12 hours total subs.
Edited by Euripides, 02 September 2020 - 09:04 AM.
#20 Paul Garais
Paul Garais
Posted 02 September 2020 - 10:24 AM
The tolerance and sample radius seem to be extremely high. I never used values that big, so can not tell if they cause issues.
The patches you are talking about are normal and likely the result of too strong denoising the background and stretching too far. But hard to tell without knowing your exact workflow.
How does the image look if you only stretch it slightly after DBE and without applying denoise or anything else?
#21 RJF-Astro
RJF-Astro
Posted 02 September 2020 - 11:02 AM
Could be a combination of noise reduction and not enough dithering. So it starts with fixed pattern noise and then turns into patches with noise reduction.
#22 Euripides
Euripides
Posted 02 September 2020 - 04:24 PM
This is a comparison between DBE and ABE , both with the same small stretch. I believe that DBE is better.
Here are shots with my workflow
https://www.dropbox....MuMKtzA6fa?dl=0
I believe that star reduction amplifies the issue.
PS. I've included the picture above into the folder.
#23 Paul Garais
Paul Garais
Posted 03 September 2020 - 07:28 AM
Your DBE is fine, in my opinion. As RJF-Astro says: Your main issue is the noise. In your images prior to noise reduction you can clearly see some diagonal structures in the noise pattern. You can avoid this by dithering. Or, as I learned here on cloudynights: Dither or die!
Your noise reduction is definitly the cause for the issues/patches you get. The best advice regarding noise reduction, I can give: Do not kill the noise and every single ancestor and descendant of it. It is called "reduction" not "wipe out" ;). Noise is not bad, it helps to keep a natural look to an image. But it needs to be reduced to a point where it is not dominant anymore. So the best approach is, to generate as less noise as possible while shooting an image. Dithering is one part of avoiding noise.
#24 Euripides
Euripides
Posted 03 September 2020 - 07:55 AM
Ok, so then I’m dying cause I do not dither :-)
Probably I have to check again EKOS and give it a second chance.
Sent from my iPhone using Tapatalk
#25 Euripides
Euripides
Posted 20 September 2020 - 10:01 AM
Ok so...I took 10 hours of M31 with PHD2 & dither.
306 x 2' @f3.2 , ISO100 with SkyTech LPRO Max filter from bortle 8-9, with flats & bias. Darks made the final result worse, so DEL.
But probably I am doing something wrong...
I've tried multiple times DBE and ABE but no matter what, I always get those ugly patches. I've also minimised my denoise.
If anyone had the time to take a look, this is the final stack cropped.
https://www.dropbox....QIZ9PukYNa?dl=0
I am getting better with my actual targets but I have certainly issues with my background :-( Any tips for the DBE points would be more than welcome!
Edited by Euripides, 20 September 2020 - 10:02 AM.
