OSC vs MONO image challenge
16 replies to this topic
#1 sn2006gy
sn2006gy
    Vendor - Rockchuck Summit Observatory
  • Loc: Austin, TX
Posted 01 September 2020 - 02:20 PM
I'd love to do an OSC vs Mono challenge on here.  I have a 2600mc, i know there is no (currently available) mono variation of it, but i'm happy to image something (similar objects) with anyone running any mono and compare results.
Let's say we pick a handful of targets in NB and Broadband and share our results (limit targets to keep this from just being an astrobin mirror)
Anyone interested?
Not even worried about the methods used... use what you do natively for osc and natively for mono.  Just want photos to speak for themselves.
Any targets that would be good for this?
  • elmiko likes this
#2 Huangdi
Huangdi
Posted 01 September 2020 - 06:53 PM
I think the reason that these challenges don't really exist is because the outcome is easy to foretell. Given proper acquisition, calibration, integration and processing, the mono image will have increased resolution, no matter what. That's really the end of it.. I don't see why you'd need a comparison for that. But I'd be curious to see some results anyway. Sadly I don't have access to either at the moment.
Edited by Huangdi, 01 September 2020 - 06:53 PM.
  • Jim Waters and Peter in Reno like this
#3 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 01 September 2020 - 07:15 PM
waytogo.gif  +1
#4 Jeff2011
Jeff2011
  • Loc: Sugar Land, TX
Posted 01 September 2020 - 08:34 PM
These comparisons are interesting but provide no definitive conclusions.  There are too many other factors involved than just the cameras.  I have both types of cameras.  Modern backlit OSC using bayer drizzle can hold there own against mono LRGB.  The real power and advantage of mono cameras is narrowband.  The multi-band pass narrowband filters for OSC just don’t give you the control and flexibility that mono narrowband has.
  • dvb, Jim Waters, Peter in Reno and 1 other like this
#5 SeymoreStars
SeymoreStars
  • Loc: Pennsyltucky
Posted 01 September 2020 - 08:53 PM
That give me a great idea for a challenge. These two images were created from the same location, same equipment. The only difference is the filters.
sn2006gy try your hand at recreating these with an OSC.
First the RGB
Second the Narrowband in HOO palette.
  • Jim Waters likes this
#6 AtmosFearIC
AtmosFearIC
  • Loc: Melbourne
Posted 01 September 2020 - 08:54 PM
It's really not that simple I'm afraid. A vast majority of the imaging I've been doing for the last few years has been a mixture of mono and OSC with wide field images. Now with wide fields there is a definite resolution increase with mono over OSC. Drizzle integrating does help with colour fidelity but nothing beats the raw resolution of mono with wider fields.
I've personally found that getting a FWHM below 2.4 pixels with a OSC is nigh impossible. Bayer drizzle does help tighten that FWHM a bit as against a normal drizzle or no drizzle at all but it is a limiter. On mono however the lowest FWHM in a stack I've ever managed with 1.3 pixels with a Sigma Art 85mm @ F/2.8 in the centre with an ASI1600. It gets difficult to measure at that point though when a lot of the stars are pretty much single pixels but that would NEVER be possible with a OSC.
Now where this gets more complicated is at longer focal lengths and higher image scales. If you can sample at 3 pixels then interpolation should no longer cause a blur and you end up with just raw resolution. I've gone and had a look at a whole bunch of higher resolution images of Eta Carina on AstroBin.
OSC:
This first one I'd say is the cheapest and most basic setup, actually kinda admire the result taken with 2000+ 3s
https://www.astrobin.../full/f5xgzx/0/
The second has potentially the best fine structure detail out of all the OSC and RGB images.
https://www.astrobin.../full/tlj3q7/0/
The third shows where the resolution can be stumped with wider field and the bayer matrix. A mono could have better details.
https://www.astrobin.../full/vv8yjn/B/
Mono:
The first one shows what small aperture and mono can achieve. Given the image scale it could potentially be done with a OSC too but absolute resolution is likely aperture halted.
https://www.astrobin.../full/pgp2ee/0/
The second is a HaRGB and one that I thought was going to show more than it does, lots of Ha showing but lacking fine structure.
https://www.astrobin.../full/he247b/0/
The third has lots of structure but lacks finer details compared to the second OSC
https://www.astrobin.../full/401472/0/
The forth is the beginning of the narrowband, softer than I was expecting from such a large instrument.
https://www.astrobin.../full/3saz7q/0/
The fifth I think is the same instrument (different data set) but appears to have a higher contrast than the forth.
https://www.astrobin.../full/7jop5a/C/
The sixth has the highest resolution/detail of the whole lot.
https://www.astrobin.../full/7sed56/0/
So, what I am getting from this list is that the highest resolution images aren't always going to be from a mono. When it comes to picking up global detail (nebulosity) being able to do narrowband helps considerably, whether it be full narrowband or a HaRGB. Out of this list of 9 images the best on a resolution stand point is a SHO image taken with a 16" RCOS from Chile, shock horror haha
What did surprise me a little was that the best non narrowband image to my eye was taken with a OSC on a Mewlon. It came close to the last on the list but not quite but it bested all of the others in my opinion.
  • Mert and Jim Waters like this
#7 SeymoreStars
SeymoreStars
  • Loc: Pennsyltucky
Posted 01 September 2020 - 08:59 PM
Gorgeous images AtmosFearIC.
#8 jdupton
jdupton
  • Loc: Central Texas, USA
Posted 01 September 2020 - 09:01 PM
Julian,
   Is CFA Drizzle not a proper integration method? If you use CFA Drizzle on an OSC it will have the same resolution as its mono counterpart (if the same sensor is available in both varieties).
   Just playing devil's advocate here...
John
Edited by jdupton, 01 September 2020 - 09:04 PM.
#9 Alex McConahay
Alex McConahay
  • Loc: Moreno Valley, CA
Posted 01 September 2020 - 09:45 PM
If you call it a challenge, yeah, it could be fun.
But if you call it an experiment, there is just no way it will really prove anything. Too many variables changing. An experiment changes only one variable at a time.
And the biggest variable would be processing. We did several shows on The Astro Imaging Channel where we provided identical sets of data. (Everybody processed the same data.) A dozen imagers processed the data. The resulting shots were dramatically different. Just not the same. Star size was different, color was way different, sharpness, noise reduction, everything. They were just different shots. If you can get that much difference with identical data, what could you possibly prove with different data?
Alex
#10 noodle
noodle
  • Loc: Hong Kong
Posted 01 September 2020 - 10:22 PM
I did a similar test  a few years ago  :)
STF8300MM (mono CCD)  vs  CentralDs 5Dii (modified  OSC)
both images are calibrated with PI  and non-linear stretched with auto stf/ histogram transf.  , no futher processing .
shooting info. :
https://astro-noodle...l?view=flipcard
  • bugbit likes this
#11 AtmosFearIC
AtmosFearIC
  • Loc: Melbourne
Posted 01 September 2020 - 10:38 PM
I wish I took that last one! The resolution and image smoothness is pretty fantastic.
Julian,
John
Theoretically that may be the case but it has never been my experience in practice except for when sampling allows.
Alex
I completely agree to this. The fourth and fifth image that I found on AB are taken with the same instrument (500mm ASA astrograph) and 16803 but have quite different images. A part of this could very well be from different processing rather than anything else.
#12 GA-HAMAL
GA-HAMAL
  • Loc: Poland
Posted 02 September 2020 - 01:43 AM
I did some interesting tests once.
Plexiglass strip with lines from the printer.
IMG_2901x.jpg.12b9052e0652ae258d79385ca4
Atik Titan mono and color camera.
Adjustment: pixel line - no pixel line - pixel line
mono
MC-ATM.png.3b429160714c2b6968f1501d51601
color
stripes set on a bayer mask GRGRGR...
MC-ATC1.png.ba091841d157a35db8c8da4fbd7d
MC-ATC1a.jpg.0d1a27675aefe33aca04906bffe
stripes set on a bayer mask BGBGBG...
MC-ATC2.png.341302a2c4bc58655f1234753a46
MC-ATC2a.jpg.e5d5967fce7e43689e607004484
Edited by GA-HAMAL, 02 September 2020 - 01:54 AM.
  • Lead_Weight likes this
#13 GA-HAMAL
GA-HAMAL
  • Loc: Poland
Posted 02 September 2020 - 01:45 AM
test not subject to weather and seeing fluctuations
Atik Titan mono
xxx-mono.png.af1ab8ec01851b622c8d36ed242
Atik Titan color - debayer
xxx-color-color.png.9f1d4247d3d35d0442cb
Atik Titan color - lum
xxx-color-lum.png.41075c7854263b78f8b98d
Atik Titan color - fit
xxx-color-RAW.png.ae68cc357c1e60ada49f97
and an interesting final comparison of mono and color - stack 1000 frames
ATIK-TITAN-MONO.png.8766d30ba4d45f6a13d2ATIK-TITAN-COLOR.png.4f210457fa4707575c1
Edited by GA-HAMAL, 02 September 2020 - 02:15 AM.
  • Dean J. likes this
#14 AtmosFearIC
AtmosFearIC
  • Loc: Melbourne
Posted 02 September 2020 - 02:09 AM
The OSC is holding up better than I was anticipating against the mono being pushed at the edge of the resolution limit.
  • GA-HAMAL likes this
#15 GA-HAMAL
GA-HAMAL
  • Loc: Poland
Posted 02 September 2020 - 02:13 AM
Well, I was surprised too.
Each stack is 1000 frames. I used dithering by pressing the base on which the optical assembly stood so that the image migrated at the subpixel level.
Edited by GA-HAMAL, 02 September 2020 - 02:20 AM.
#16 rockstarbill
rockstarbill
  • Loc: Snohomish, WA
Posted 02 September 2020 - 03:53 AM
Sure bro, lets go.
PacMan Nebula is the target. HA vs HA on OSC. Get prepared to be wrecked. You will use an HA filter right? If not -- the test is flawed.
Image scale is 0.9"/px. AGO 10" IDK, ASI6200MM-Pro camera, Chroma 3nm HA filter.
Edited by rockstarbill, 02 September 2020 - 04:02 AM.
  • idclimber likes this
#17 freestar8n
freestar8n
    Vendor - MetaGuide
  • Loc: Melbourne, Australia
Posted 02 September 2020 - 06:00 AM
There is absolutely no reason to expect a loss of resolution with OSC if Bayer drizzle is used and if the exposures are dithered.  Both mono and osc involve stacking individual pixels - individually - with alignment into a final image.
There is very little difference to expect a loss of efficiency either - since the filter bands are broader with OSC - and they are a better match to the eye.  This is particularly true if the mono filters have a big gap in them for light pollution - and you either image from a dark site or your sky background has no emission peaks in the gap.  You would then equally lose light from the sky background and any continuum objects you are imaging such as galaxies.
There is a doubling of G pixels in OSC - but that acts in a similar way to combining L with RGB - since a dominant component of L is from G.
These topics have been gone over many times.  Mono and OSC are fundamentally different - and as mentioned above there is a great variation of results due to processing even when given the same data.
If people try both and try processing different ways they may come to have a strong preference.  But there is no simple explanation for it that I'm aware of.  Loss of resolution and loss of photon count simply don't apply.  They are just different.
Frank
  • Joe G, jdupton, Dean J. and 1 other like this
