Sean,
Get on YouTube, do a search for Dave Trott + Teegul to see how he solved the problem of the center of gravity of his Space Patrol mount. I think he could make some money marketing that solution, but I’m guessing there are not enough of those mounts to actually make very much profit.
As you and I have discussed off of the Cloudy Night forum, I have the exact same mount, with the optional GEM parts and polar scope. It is also the Space Patrol II. I’ll post a picture of how I use it now and my reasons for this configuration.
I chose a Berlebach tripod, largely because I had read about it from another post as being used with this particular mount. It was a good choice, but everything in life is a trade off, and this is definitely what we deal with in our hobby/love.
I originally tried using the Teegul in the German equatorial configuration, but it presented some unique problems. To begin with, I have real mobility issues. Because of my age and a nerve disorder, I walk with aid, have very poor balance, and lack strength and dexterity in my hands. The Teegul in the GEM configuration coupled with a comparatively heavy wooden mount whose legs tended to collapse (I bought the tray later) was causing problems getting the telescope out the door. The weight of the GEM tended to make it top heavy when transporting it also.
This mount also has a RA locking screw that prohibits it from doing the “meridian flip” when crossing from one side of the sky to the other. I actually haven’t tried to use the polar scope. I’m not using my setup for astrophotography, so I just point the polar axis in the general direction of Polaris and it works pretty well. I’ve got an idea about how to use the polar scope if I were to ever mount my little telescope on a permanent pier, but I believe it would be too complicated to do it each time I moved it outside for each viewing session.
I really appreciate the mount and tripod the way I have it configured now. One thing I like is the aesthetics of wood. I now own a matching Berlebach observing chair and the whole system is a source of pride. I added the tray below that keeps the legs from collapsing, but they now have a tendency to catch on things I’m trying to walk past. Still an improvement in moving though.
As far as the tracking ability of the mount, it is doing a fairly good job, but I’ve experienced some problems that may be due to operator error, but I’m not sure. Because of my lack of dexterity, I think I was failing to get the clutch screws tightened adequately. If too lightly tightened, neither of the RA or DEC slow motion knobs would move the tube. If tightened too much, the slow motion knobs were too difficult to move the tube. My mount has to have the tension on the clutch screws adjusted just right for the slow motion to work properly AND the tracking to work properly.
I have also experienced a problem with the tracking at times. The telescope tube will be tracking fine and then just stop for a while. I can fiddle with the RA slow motion, rack it back and forth, and then it will start working again.
In our offline correspondence, you are discussing either a Berlebach or carbon fiber tripod. In hind sight, carbon fiber would certainly be lighter to move around. It would also make the whole thing much top heavier for moving around. For aesthetic appeal I like wood!
Either way, I would opt for a tripod head that can swivel to help in aiming to polar north, and a head that can crank up and down to bring the eyepiece to a comfortable height. My tripod head on the Berlebach can swivel, which I appreciate, but can’t be cranked up and down. I have another tripod with an alti-az mount that can crank up and down and it makes viewing sooo comfortable and easy.
My two cents and some change Sean. I really look forward to hearing your thoughts and experiences about your unique mount!
