Help with AT65EDQ Focuser Knob?
7 replies to this topic
#1 Scott Mitchell
Scott Mitchell
  • Loc: Atlanta-ish, GA
Posted 14 September 2020 - 07:31 PM
Hi everyone, I was hoping someone could help me figure out how to remove the coarse focuser knob from my AT65EDQ so that I can attach a stepper motor.
The picture below shows the focuser, and there you can see the socket in the right-hand knob for the set screw. I have removed the set screw, but I still can't get the knob off. I can get the know to rotate (without the focuser racking in/out) when the set screw is removed, but something seems to be preventing the knob from slipping off.
I'm a little terrified to pull super hard (but honestly I've just been pulling harder and harder to no avail). Anyone have any ideas what I'm missing here?
#2 syxbach
syxbach
  • Loc: West Texas
Posted 15 September 2020 - 09:42 AM
Let me answer this questionlol.gif  The knob is very tight. You might take the pinion off and remove it carefully.
Yuexiao
  • Scott Mitchell likes this
#3 Scott Mitchell
Scott Mitchell
Posted 15 September 2020 - 11:48 AM
Yuexiao
Thanks Yuexiao. You would certainly have good insight to share there. Maybe I'm just not pulling hard enough.
When you reference using a tool, what are you thinking there? Something to pry the ends of the knob up?
#4 syxbach
syxbach
  • Loc: West Texas
Posted 15 September 2020 - 01:13 PM
I have no idea about the tool. When I disassembled the motor from it before I sent it to you, it was pretty tight, but I still managed to take it out or insert it in.
#5 Scott Mitchell
Scott Mitchell
Posted 15 September 2020 - 01:33 PM
#6 fmeschia
fmeschia
  • Loc: Mountain View, CA
Posted 15 September 2020 - 03:33 PM
Double check that you have unscrewed the set screw enough... ideally you may want to remove it altogether. The pinion shaft has a machined flat for the set screw, but it doesn’t get all the way to the end of the shaft, so if the set screw still protrudes a bit into it, the knob won’t come off.
#7 Scott Mitchell
Scott Mitchell
Posted 15 September 2020 - 06:03 PM
Yeah, I've been going on and taking it out entirely (mostly because I was afraid of it randomly falling out and never being seen again).
One suggestion was that there may be a second, interior screw holding the knob in place, but I can't find any evidence of that.
Sent from my iPhone using Tapatalk
#8 fmeschia
fmeschia
Posted 15 September 2020 - 11:17 PM
On mine there isn’t any second set screw – but I bought it second-hand, so it might have originally been there.
