If you have not tried Astrosurface yet you really should
11 replies to this topic
#1 GSBass
GSBass
  • Loc: South Carolina
Posted 16 September 2020 - 09:54 AM
I know most old timers here are prone to stick with what they know but I really think you will be surprised how great Astrosurface is, I think the users manual is still in translation but the learning curve is not too steep, probably one of the biggest things to understand is the decovolution control is married to the hf wavlet control so if you adjust one it affects the other.  Anyway the program is under active development and is a winner, fast and reliable
#2 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 16 September 2020 - 10:21 AM
I gave it a try after watching Jean Luc D'Auvergne's youtube vids. Trouble is they're in french, but as hes talking astro and you can see what he's doing, you can understand maybe 20% of it!
Im aware it has potential for sure. Interested if anyone has more info or how-to advice. If it can batch process wavelets to the quality of registax im in.
#3 GSBass
GSBass
Posted 16 September 2020 - 10:25 AM
I think maybe a sticky might be good for users to post various instructions.... everything is not clear to me but I know enough to get people up and running
#4 Xeroid
Xeroid
  • Loc: USA
Posted 16 September 2020 - 10:32 AM
It would be most helpful if you could briefly describe what does Astrosurface do?
#5 sg6
sg6
  • Loc: Norfolk, UK.
Posted 16 September 2020 - 10:35 AM
I don't understand one bit of that statement. lol.gif  lol.gif  OK maybe the first 9 words, after that not a clue.
#6 GSBass
GSBass
Posted 16 September 2020 - 10:44 AM
The very basics
1) file- import ser or avi
2) click on analyze/register
3) now you have a window of 4 panes, each pane is a step, so you have to go in order
4) first pane is detect, click on detect disk, it will draw a box around your planet
5) you have to double click on the planet, then the next pane will highlight
6) click analyze
7) once analyze is done you can either click on graph to select frames to stack or just go on to next pane, if you go on it’s going to do 50% of your best frames
8) the next pane lets you choose global alignment or select pixel alignment, I use pixel and it’s fine to start off with what is showing as default, so now click set and you will see grids on top of your planet
9) then the final pane lights up, just click stack
10) after stack is done it will auto save to an aligned file in whatever capture program you are using.
11) close your preview and analyze windows and start fresh
12) file- open
13) select the file it just saved
14) your stacked image is on screen so now just click wavlets
15) you will need to draw a box around your planet, play with all the sliders and just watch your planet transform, once your pleased then click do all
16) your now ready to save as, or continue with other image processing, there is a lot you can do but those are the basics steps to get you there
  • Jim R likes this
#7 GSBass
GSBass
Posted 16 September 2020 - 10:47 AM
Once you get in to the wavlet processing part of the program you will see various sliders.... it’s just a matter of playing with them to tweak your image, I was just trying to say some of them effect others while others are independent of each other
#8 GSBass
GSBass
Posted 16 September 2020 - 11:00 AM
Sure, Astrosurface combines a stacking program with a wavlet program, most people use multiple programs, I’ll refrain from saying one is better, I just don’t have that experience.... I can only say Astrosurface is very good, I imagine some will like it better and some worse, I just like it alot so spreading the word, It’s free
Edited by GSBass, 16 September 2020 - 11:00 AM.
  • Gary Z likes this
#9 happylimpet
happylimpet
Posted 17 September 2020 - 04:27 AM
Aha! I didnt know it stacked also! Have you done a comparison with AutoStakkert to see if it equals or even surpasses it?
#10 GSBass
GSBass
Posted 17 September 2020 - 09:20 AM
I won’t be doing any direct comparisons do to limited experience, however there is a great deal of control over which images get stacked that was not obvious to me early on, I had been just stacking the best percentages but the program does allow you to reject frames, select certain segments to stack etc, I can’t write a how to on this yet but the tools are there to do this..... as far as the stacking itself, I see no bad stacking, seems to work perfectly, I have a slow computer and it takes a few minutes to stack 2000 frames or so, when I stack 10 to 15000 it has taken about 15 to 20 minutes
Edited by GSBass, 17 September 2020 - 09:21 AM.
#11 Phguy65
Phguy65
  • Loc: Hudson Valley area, New York State, USA
Posted 20 September 2020 - 01:27 PM
Thanks for the tip GSBASS.  I downloaded this yesterday and have been processing some short captures of Mars, Jupiter and Saturn.  I am by no means a master at processing but this app got me some good looking images pretty quickly.  To me, it has a better flow that Registax6, which often had me pulling my already thinning hair out.
So I capture my images in SharpCap, then pre-process with PiPP then finish with Astrosurface.  I suppose if I was really tweaking the images I could go on to GIMP but I just like processing the images for my own quick analysis.
Thanks again!
  • GSBass likes this
#12 GSBass
GSBass
Posted 20 September 2020 - 09:10 PM
I’m glad you liked it, I downloaded pipp but have not tried it yet, my work flow is sharpcap/astrosurface then I attach my harddrive to my iPad where I have a variety I try, I like some tools in snapseed, I have affinity and an old program called Leonardo that I know well.... even apples edit tools work well on some stuff
Thanks again!
