Regular Barlow vs. Shorty Barlow
18 replies to this topic
#1 mistercrisp
mistercrisp
  • Loc: Sea Cliff, NY
Posted 16 September 2020 - 10:56 PM
I am curious about the differences between regular 1.25 barlows and shorty barlows.  Can anyone offer their experiences?
thanks,
ken
#2 Hugh Peck
Hugh Peck
  • Loc: NE WI
Posted 16 September 2020 - 11:20 PM
Had a couple 3 element "shorties" and they were okay in the f/10s but not in the f/5s. Not good at wide fields, losing it around the edges. Can't say about "regular" ones as only ever had two, one for newtonians and one .965 that came with an old used orabge tube C-90. Never really used either.
  • mwedel and cookjaiii like this
#3 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 17 September 2020 - 12:48 AM
There's a fundamental principle in lens design... to avoid unnecessarily powerful ~ray-bending~ because that's where aberrations come from... related to violation of the very fundamental sine condition and other arcane ways we optics guys think of how much work we are imposing on the lenses and mirrors. I learned that personification of lenses from Kingslake and Sinclair (Rudolf and Doug) very early on.
The Shorty Barlow pays the price of its compactness by... having to bend (refract) the light more severely. The price is poorer performance. It's like it got to the ray-bending too late, so has to put the brakes on the too-fast feed harder, too close to the image. All sorts of things get worse than had a more gentle negative achromatic relay intercepted the light a little earlier in the game. Really no free lunch in optics. The more you try to compact a scope, the harder and harder it is to achieve good performance. And that's why a plain vanilla slowish Newtonian... is the conservatively-best telescope. One single gentle ray-bender (the PM) and maybe, just maybe a rather benign refractive field corrector. Compare that with a Schmidt Cass... which most all are out of alignment and have choked field with giant central obstruction. Note that the convex SM mirror in Cass (and its derivatives) is nothing more nor less than a camouflaged reflective Barlow --- and therefore inefficient, right out of the blocks!    Tom
  • CeleNoptic, george tatsis, chrysalis and 1 other like this
#4 213Cobra
213Cobra
  • Loc: Los Angeles, California, USA
Posted 17 September 2020 - 01:55 AM
thanks,
ken
We have a ShortyBarlow here: https://www.cloudyni...-shorty-barlow/.
Maybe he weighs, say, 160 lbs. or more. I'm pretty sure most regular 1.25" barlows weigh much less. So, you might consider that.
Phil
  • Light Bender likes this
#5 MartinPond
MartinPond
Posted 17 September 2020 - 08:05 AM
After testing a number of Barlow Shorties  (1.25" context):
--The 2-element achromatic cell in most brand-name 2X  (Meaded, Celestron, etc)
   Barlows does quite well, chromatically.  In fact, the optical cell from a Meaded #126 can be
   swapped onto a long Orion Tri-Mag, and matches  the 3X power and lack of chromatism.
   There is a bit less cntrast....the Tri-Mag front cell holder has a bit better light baffling..
---Many older shorties had contrast issues.  They have an open inner tubing and
   less threaded or  stepped walls.   A internal restriction fixed that, but now
   the more recent shorties have vignetting (field reduction) for longer-fl eyepieces.
---3X shorties have more severe vignetting, and some astigmatism (fuzzing) before that.
   ....the Celestron 3X X-Cel LX seems to dodge that bullet well.
---To avoid any vignetting or eye-relief pushing, Telecentrics like the
    ES focal extender or the Televue Powermate can be used.
    Most handy for long-focal-length(FL)  eyepieces.
-----> There is a very cheap SVBONY Barlow.  Some say it's great, and has a real
         achromatic cell.  Mine arrived coated one side only with a 1-element cell.
           Not great as a Barlow,  but made a great 1.25 extension plus iris, and the cell,
         after throwing the glass out, makes a great contrast-enhancing iris for
         short-fl eyepieces.  Fun deal for parts.....not a good Barlow...for me.
I have 3 Meade 126's, and with a 1" eyepiece extension tube, they have
   gain closer to 2x, much less vignetting, and improved contrast.
  Wonderful, when customized.
A basic Televue 2X Barlow costs more, but does things just right.
Its future value is multiplied across all your eyepieces.
The 3X X-Cel XL costs more too, but has a lot of satisfied takers.
The long Orion Tri-Mag is an excellent deal....you just have to accept the length.
Long 2X Barlows are almost non-existent.
 The Televue 2X is a "midi", middle length.
Smart design choice. that's what I made....but mine has
a bunch of electrician's tape on it.
Edited by MartinPond, 17 September 2020 - 08:09 AM.
  • Jon Isaacs, SteveG, mwedel and 5 others like this
#6 mistercrisp
mistercrisp
Posted 17 September 2020 - 10:18 AM
Wow, thank you all for your valuable comments and observations!  I appreciate the "why" of the problem of the short barlows, in terms of how optics work.  Thank you all SO much!
Ken
#7 MitchAlsup
MitchAlsup
Posted 17 September 2020 - 11:27 AM
Well said.
#8 Jon Isaacs
Posted 17 September 2020 - 02:09 PM
Ken
Ken:
I regularly use both standard GSO Shorty's and a 2x 1.25 inch TeleVue midl length Barlow.
My scopes are generally around F/5 and I have a variety of eyepieces by my main set is all TeleVue.
In terms of use in the field and not theory, the Shorty Barlows do very well with most eyepieces. There can be vignetting with long focal length eyepieces and some long focal length, wide fields show odd off axis reflections.
But with mid focal length length and short focal length eye pieces I find the Shorty's to be good performers. The main issue is not sharpness but scattered light that reduces contrast slightly when viewing the planet's.
Regarding Tom's comments:
Eyepieces often use severely curved optical elements, comparatively Shorty Barlows are mild compared to many eyepieces.
https://www.chuckhaw...ece_designs.htm
Any shorter focal length eyepiece with acceptable relief will include a Barlow like doublet that's like more than 2x and shorter than a shorty Barlow.
  • aeajr likes this
#9 SteveG
SteveG
  • Loc: Seattle, WA
Posted 18 September 2020 - 01:41 PM
How does the mid-length TV 2x hold up with a 24 mm widefield? Does it vignette?
#10 MartinPond
MartinPond
Posted 18 September 2020 - 03:13 PM
Jon might be able to check that out for you..
"-----How does the mid-length TV 2x hold up with a 24 mm widefield? Does it vignette?---"
I need to look up the widest 1.25//25mm...
Looks like Agena lists a 25mm // 58degrees
Others are similar..
For more afov at 1.25 you may need to step down in FL.
I have the "Po'boy" version, the stretched Meade #126.
I project   55 degrees (down from 57) at a 23mm FL.
So...there is a little restriction in the body still.
If I do the whole distance in 1.25 OD barrels taped, I get all 57 degrees.
And...all 70deg  of a 20mm/70deg.   Very dark inside, too.
Long flat-blackened threading has been a staple for many Zeiss
   widgets for over 100 yrs.
Trimming a 1.25 lavatory (bathroom sink) extension tfor 2X and lining it with
  1.5 wraps of pressed-outward  drywall sanding mesh (the best blacking!)
https://www.homedepo...790BG/205153709
 ...gives up all 57 degrees as well.
Not as sleek as the TV 2X, of course, and the TV claims high-index glass.
It does have that dandy LPDE compression ring EP holder, though.
Something I wish they built into scope accessories  ... no lame/bent copper rings.
Edited by MartinPond, 18 September 2020 - 03:22 PM.
#11 Thomas_M44
Thomas_M44
  • Loc: Modesto, CA USA
Posted 20 September 2020 - 05:58 PM
I have only one suggestion:
Unless it's physically/mechanically impossible to use a longer Barlow with your telescope and associated optical accessories, I suggest always going with a higher-quality standard-length or long Barlow.
"Shorty" Barlows may be practically necessary some times, but are almost always somewhat inferior to regular/longer Barlows --assuming similar optical (lenses and coatings) quality, of course.
Edited by Thomas_M44, 20 September 2020 - 06:00 PM.
#12 Peter Besenbruch
Peter Besenbruch
  • Loc: Oahu
Posted 20 September 2020 - 08:36 PM
Shorty Barlows tend to work better in star diagonals. 3 element shorties do better than 2 element optically. The Celestron X-Cel LX Barlows use a longer top portion (where you insert an eyepiece than the 2x. Vignetting is minimal with either the 2x or 3x. The opposite extreme is the Baader Q Barlow, which vignettes most of my eyepieces. The X-Cels have some of the best light control I have seen. Explore Scientific (not a shortie) and Meade have some of the worst.
  • CeleNoptic and Nate1701 like this
#13 Jon Isaacs
Posted 21 September 2020 - 06:28 AM
That has not been my experience.  For me, the main difference is the coatings, more scatter.  Typically though I only use Barlows with medium and short focal length eyepieces.  Generally Barlows improve the view of eyepieces that are not will corrected off-axis.
#14 Ernest_SPB
Ernest_SPB
  • Loc: St.-Petersburg, Russia
Posted 21 September 2020 - 11:23 AM
In other aspects equal short focal Barlow performs better on axis and introduces more off axial aberrations and wide field artifacts (like vignetting and FOV cut).
#15 DRodrigues
DRodrigues
Posted 22 September 2020 - 07:22 PM
I like the use of barlow cells on my day.light use because of their compactness, specially important on spotting scopes.
The Baader Hyperion zoom barlow cell results well as a compact 2.25x barlow - e.g http://www.pt-ducks....3_ESBA_92_5.JPG
See text about the adapters almost at the end of the text at http://www.pt-ducks....f 5mm eyepieces
  • aeajr likes this
#16 Jon Isaacs
Posted 22 September 2020 - 11:50 PM
If you're thinking of the Baader zoom Barlow:
Be aware that the Baader Hyperion Zoom Barlow has a clear aperture of 13.2 mm.
https://agenaastro.c...ow-2454827.html
  • eblanken likes this
#17 DRodrigues
DRodrigues
Posted 24 September 2020 - 06:14 PM
Yes, but 13.2*2.25 is equivalent to 29,7mm - no 1,25" ep will vignette and several 2" also will not.
Unlike other 2 to 2.5 barlows that reduce the effective power increase by using only the barlow cell alone, on this you get always >2.25x increase
#18 Jon Isaacs
Posted 25 September 2020 - 05:24 AM
I don't think it is quite that simple. Other Barlows with more than 20mm clear aperture vignette with eyepieces with larger field stops.  What you have calculated is the effective field stop diameter with a 2.25x Barlow in place.
That is valid at the focal plane but does not address how the focal plane is illuminated by the converging rays from the Barlow.
Have you tried eyepieces with a 29.7mm field stop with the Baader zoom Barlow?
#19 MartinPond
MartinPond
Posted 25 September 2020 - 01:26 PM
Under the heading of:   "not necessarily":
There is a peculiar side-effect of at least one telecentric multiplier.
The ES 3X  Focal Extender has lenses that are a full 1.25" in diameter
(not diminished by the usual barrel thickness) and somehow produces
a 57 degree afov   with a  few 30mm//53-degree eyepieces I have.
A handy  feature, this opposite-of-vignetting.
This is in a fat 80x400 scope, if that figures into it somehow.
  • mwedel likes this
