CEM25P Off Target after Flip
4 replies to this topic
#1 vwmj1
vwmj1
  • Loc: Gibraltar/Andalusia Espana
Posted 20 September 2020 - 05:42 AM
Under hits own control , i.e. no software such as APT or ASIAIR, when my CEM25P flips it is not on target. Well off actually, to the extent I haven't been able to identify how far off.  The original target is definitely not in the pictures.
What am I doing wrong?
I'm sure it's something to do with the set up and suspect it's related to Zero Position.
Polar Alignment is accurate. I always take my time with this, and ensure it hasn't moved once I've got all the equipment mounted and running.
I only do a one star alignment. When tracking the mount is locked on target with no slippage errors.
Meridian Treatment is set at 5 degrees.
Reading other threads I know this can be solved, but I've not seen a specific thread dealing with this issue.
#2 james7ca
james7ca
  • Loc: San Diego, CA
Posted 20 September 2020 - 06:36 AM
Could be cone error that can be reduced (or corrected) by shimming the rings/dovetail. Also, you mount's polar alignment/setup/calibration procedure should help correct for cone error but it probably doesn't do so perfectly.
In any case, if you want automated, accurate framing after a meridian flip you'll probably have to use plate solving to recenter the target. The only other solution would be to develop a pointing model for your mount (requires special software and best used on a mount with absolute encoders).
Edited by james7ca, 20 September 2020 - 07:00 AM.
  • vwmj1 likes this
#3 ShortLobster
ShortLobster
  • Loc: Stamford, CT, USA
Posted 20 September 2020 - 08:08 AM
As mentioned above, the best solution is to do a plate solve after a meridian flip.
You want your meridian flip to be controlled by your imaging software. I use that mount with an ASIAIR Pro, which initiates the flip, plate solves a couple of times and then restarts guiding. It's been nearly flawless for me, with alignment after the flip at 179.9 degrees as measured in DSS.
  • vwmj1 likes this
#4 vwmj1
vwmj1
Posted 20 September 2020 - 09:24 AM
Thanks guys. Grateful for the advice.
I thought it might be a software required solution.  I am using APT, so I'll do that next night out.
Not got round to the ASIAIR. Saving it for a couple of weeks off at the end of the month.
#5 ShortLobster
ShortLobster
Posted 20 September 2020 - 09:33 AM
I was a bit skeptical of the ASIAIR Pro, but have to say it was a game changer for me. So simple to set up for imaging, everything is integrated and works great. Still a bunch of features I hope they add (e.g., auto-focus, support for PHD2's PPEC algorithm), but totally usable for most of my needs already.
