ZWO asi183mc pro not focusing
5 replies to this topic
#1 Zeezomax
Zeezomax
Posted 20 September 2020 - 10:49 AM
Just bought a zwo asi183mc pro. I couldn't get a clear image both in light polluted and not so polluted areas.
I'm using it with a skywatcher startravel 102T with 500mm focal length. Mounted on a skywatcher az gti in equatorial mode. Powered by 150w battery inverter. And using an ASiair pro to control everything.
Any suggestions? Thanks.
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 20 September 2020 - 11:02 AM
Assume that you cannot wind the focuser inward sufficently??
In a way makes sense - the 102 Startravel is basically a visual scope and not intended for having a camera attached so there is insuffucent focuser travel provided.
If it were outward travel the solution is add an extension, insufficent inward just cannot be sorted. You cannot remove (sensibly) length of the OTA.
Not all scopes are suited for AP.
Edited by sg6, 20 September 2020 - 11:03 AM.
#3 gustavo_sanchez
gustavo_sanchez
  • Loc: Puerto Rico, US
Posted 20 September 2020 - 11:09 AM
I would try using the camera during the day with a far object, and try using an extension to see if it gets closer to focus. Usually is not the camera, but the scope.
Sent from my M2002J9G using Tapatalk
  • Ken Sturrock likes this
#4 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 20 September 2020 - 11:30 AM
Roughly measure 500mm from the 102's objective, that's where the ZWO sensor needs to be.
You'll probably need a spacer, measure with the 102's focuser halfway out.
The sensor is 6.5mm in from the front plate of the ZWO.
#5 Zeezomax
Zeezomax
Posted 20 September 2020 - 12:22 PM
Thanks everyone for your replies, I didn't use extensions provided with the camera. I'll give them a try.
#6 Zeezomax
Zeezomax
Posted 21 September 2020 - 09:53 AM
This extension tube saved the day. Thanks everyone.
  • GrafikDihzahyn likes this
