iOptron SkyGuider Pro not tracking? [Resolved]
3 replies to this topic
#1 HoloTheWolf
HoloTheWolf
  • Loc: Northern California
Posted 21 September 2020 - 01:55 AM
I received my SkyGuider Pro with iPolar last Friday. It's been cloudy over the weekend, so I didn't have much chance putting the mount in action.
Finally the clouds parted this evening, so I set up the mount polar aligned, pointed my scope to Mirach. Took a few 10~30 secs subs hoping to see
reasonably rounded stars but, to my dismay, found star trails.
Now it could be that my PA is not perfect, however, I suspect the mount's RA motor is not slewing. I am saying this because the mount has two buttons
that allow you to fast slew the RA axis. But when I press either of the buttons, nothing happens. I can't hear the motor moving. I have also tried motor
calibration, following this post, which slews RA clockwise and counterclockwise for 8mins each. The mount did not slew at all.
Before I send the mount back, is there anything I might have missed? I would appreciate your thoughts/suggestions/comments. Thank you!
- Jason
Edited by HoloTheWolf, 21 September 2020 - 12:11 PM.
#2 HoloTheWolf
HoloTheWolf
Posted 21 September 2020 - 11:59 AM
Okay, the tracking issue is resolved.
I searched SkyGuider Pro tracking issues on CN, came across DubbelDerp's post. Turns out my mount has exactly the same problem.
I opened the enclosure and turned on the power. The RA motor, as I suspected, did not move. Following DubbelDerp's steps, I tried to
block the optical sensor, and Voila! The RA motor started to move! After re-calibrating the motor (took about 16 minutes) and a few
power cycles, the mount seems to function properly. If the weather permits this evening, I'll do a few test shots to verify.
For reference, these are SkyGuider Pro motor calibration steps from DubbelDerp's post:
  1. Make sure the unit is off.
  2. Power on the unit while holding down the center button.
  3. Release the button to initiate an 8-minute slew in one direction.
  4. After the previous step is completed, press the center button again to slew the RA axis for 8 minutes in the other direction.
  5. Switch off the unit, and do a few power cycle.
- Jason
Edited by HoloTheWolf, 21 September 2020 - 12:12 PM.
  • limeyx likes this
#3 limeyx
limeyx
  • Loc: Seattle, WA
Posted 22 September 2020 - 02:03 PM
Glad you got it resolved !
  • HoloTheWolf likes this
#4 HoloTheWolf
HoloTheWolf
Posted 26 September 2020 - 08:52 PM
Guess I'm lucky the issue can be solved easily, and I didn't have to return or send it back for repair.
