Mars RGB C14 f15 Average Seeing, 9/21/20
3 replies to this topic
#1 sfugardi
sfugardi
  • Loc: MA
Posted 21 September 2020 - 07:51 PM
Taken this morning in brisk 5degC temps. Finally got my focuser working again. Only 3/5 seeing and transparency. This time, I added a small spacer on my ASI290MM to boost the f-ratio to 6000mm (f15), was f13, cut the frame rate to 250 (down from 300) and increased the RGB runs to 2min (up from 90sec). Also, this time I did not merge multiple RGBs in WJ, only the "best one". I also gave up on the game controller after accidentally parking the scope 5x and went back to the synscan hand controller. I was trying to be patient waiting for improved seeing, but conditions seems to get worse and the cold set in. I hate to admit that I should have been using hand warmers, but really in September? It seemed too early. At the end, I had put in my 13mm Nagler (300x) + Denk contrast filter and the views were pretty decent with an absolutely huge bright disk. Hope you like it
Steve
  • cometcatcher, Sunspot, JMP and 18 others like this
#2 R Botero
R Botero
  • Loc: Kent, England
Posted 22 September 2020 - 02:13 AM
Lovely Steve :cool:
Roberto
#3 sfugardi
sfugardi
  • Loc: MA
Posted 22 September 2020 - 07:19 PM
Roberto, thank you! I completely forgot to click on the the "Use Linked Wavelets" so I reprocessed the same data with improved results, except ice cap is still clipped. It's too bad Reg6 Scheme Save does not remember this...
Steve
PS: Thanks for the likes!
  • JMP, astrovienna, Mirzam and 3 others like this
#4 R Botero
R Botero
Posted 23 September 2020 - 02:25 AM
Even better! I love the colours.
Roberto
  • sfugardi likes this
