Error with final stacked image in DSS
astrophotography dslr imaging
4 replies to this topic
#1 Hyperion2
Hyperion2
Posted 21 September 2020 - 11:49 PM
So I recently captured about 2.5 hours of data on M31, with my DSLR. All the frames are closely aligned and all the calibration frames have no issue with them. However I keep running into a problem were after stacking and producing a final image, dss only gives me a master Offset where the final picture usually is. I’ve used dss multiple times before with the same camera and this never happened. How could I fix this?
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 22 September 2020 - 01:36 AM
That sounds really strange.
Are you sure it's just the offset and not final needing stretch ?
Can you put the final autosave.tif somewhere ?
#3 Hyperion2
Hyperion2
Posted 22 September 2020 - 06:02 AM
I’ve tried to put it in different locations and I get nothing it doesn’t create an image even after stacking only a master offset.
#4 Tapio
Tapio
Posted 22 September 2020 - 06:13 AM
What do you mean by "I’ve tried to put it in different locations".
How about if you stack just lights ?
#5 Hyperion2
Hyperion2
Posted 22 September 2020 - 06:22 AM
I’ll give that try I’ve removed offset data and I still get the same result which just makes no sense.
Also tagged with one or more of these keywords: astrophotography, dslr, imaging
