Stupid question about DSLR camera
4 replies to this topic
#1 ryansmonacles20
ryansmonacles20
  • Loc: Apollo, PA, USA
Posted 22 September 2020 - 01:01 AM
Before I buy a used one I wanted to find out and it’s a stupid question.
What typical damage might affect final image quality? I want to think as long as the lens is fine, the lcd screen on back can be scratched or dented, and when I want to produce the final image it will be just fine.
In other words, only a damaged lens or sensor will affect the final image?
#2 Dynan
Dynan
  • Loc: NOLA
Posted 22 September 2020 - 01:48 AM
Correct
#3 ryansmonacles20
ryansmonacles20
Posted 22 September 2020 - 02:01 AM
Correct
Thank you.
#4 Sleep Deprived
Sleep Deprived
  • Loc: Seattle Area
Posted 22 September 2020 - 02:15 AM
And, if you are using it for AP (with a telescope) the scratched lens isn't an issue since you won't be using it.  If you don't use a telescope, then, of course, the camera lens matters.  A lot.  And the sensor.  Dead/hot pixels can be deleted during post-processing, if you are going to use processing software.  If you are feeding the signal into a computer, even the LCD screen won't matter - your laptop becomes the 'LCD Screen'.
  • Dynan likes this
#5 whwang
whwang
Posted 22 September 2020 - 06:00 AM
Watch out a worn lens mount. It can lead to sensor tilt. Even a camera with a fine lens mount can have sensor tilt, and unfortunately it’s almost impossible to tell until you buy it and use it.
