ASIAIR Problems
accessories astrophotography cassegrain catadioptric EAA equipment SCT polar alignment imaging dso
5 replies to this topic
#1 Jujubean
Jujubean
Posted 22 September 2020 - 10:35 AM
I just bought an ASIAIR V1 used from the classifieds here on CN. I took it out for the first time last night, and everything worked well. However, when I came back inside to process the data, I ran into a lot of trouble. I noticed that they were saved in FITS files, and they seemed to have very little data in them. A single frame viewed from my ipad when I was imaging looked better than a stacked and processed FITS image (I'm using PS). Should I save the images onto my ipad and then transfer them to my computer? Can I change the file type?
The other issue is when I tried to insert the SD card back into the ASIAIR, it says "License Check Failed". I'm not sure what to do at this point.
Edited by Jujubean, 22 September 2020 - 10:40 AM.
#2 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 22 September 2020 - 10:41 AM
The image you were looking at on your iPad is a preview JPEG that is auto stretched. If there was a view of your target there, it’s in the fits file. It will have to be fully processed to bring out data. I think photoshop has a plug-in for fits but I don’t stack with it, so I am not sure.
I haven’t personally seen the license check error, but did you make a back up of the card’s operating system? It’s the first step in the manual.
Also I would search the ZWO forums for your error, it is probably well trodden ground over there.
Edited by wrnchhead, 22 September 2020 - 10:47 AM.
#3 Jujubean
Jujubean
Posted 22 September 2020 - 12:10 PM
I did not make a backup of the os, I bought the ASIAIR used and it did not come with the manual.
I'll try to find out what to do for the error, but I don't want to have to deal with it every time I transfer files. I fully processed the FITS data and it seemed to have almost nothing in it except stars. I got more nebulosity in a single PNG preview. It also created this horrible grid pattern on the image.
Edited by Jujubean, 22 September 2020 - 12:13 PM.
#4 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 22 September 2020 - 01:23 PM
Well you shouldn’t have to deal with the license error every time. Something funky is up with that. I don’t think there is a hardcopy manual it is all online at their website.
What processing programs are you using?
#5 Jujubean
Jujubean
Posted 22 September 2020 - 05:37 PM
I am using DSS and Photoshop. After a second processing attempt I was able to see some nebulosity but still not as much as a single frame. The FITS images also didn't contain any color.
#6 wrnchhead
wrnchhead
  • Loc: NE Kansas
Posted 22 September 2020 - 05:46 PM
Ok. This tutorial will get you some results with photoshop.
https://www.astropix...t/digtechs.html
Here is the table of contents
https://www.astropix...it/toc_dig.html
Also tagged with one or more of these keywords: accessories, astrophotography, cassegrain, catadioptric, EAA, equipment, SCT, polar alignment, imaging, dso
