Vixen R200SS connection to camera(s)
No replies to this topic
#1 bokemon
bokemon
  • Loc: Silicon Valley, California
Posted 23 September 2020 - 01:25 PM
Hello folks,
I have one of these scopes on order and want to figure out all the connecting parts.  The scope comes with what I believe to be an adapter that has 60mm threads for the focuser, 56mm internal threads for the Corrector PH to screw in, and finally presents 42mm threads towards the camera sensor.  OK, but is there another adapter so I don't have the constriction from the 42mm threads?  (probably inner diameter will be something like 39mm)  It seems a shame to have a 56mm corrector, with rear window size ---, and then to have the dumb adapter block it off.
There is another part called a Direct Wide adapter which appears to present a dovetail-type connector towards the sensor, but I wouldn't know how to connect to that with my QHY camera.  (I think you are supposed to use a Vixen T-ring adapter for a DSLR camera and then take out the inner 42mm threads?)  I don't know - online info seems scarce.
