Starsense Camera Position
8 replies to this topic
#1 Mapkos13
Mapkos13
  • Loc: Cincinnati, OH
Posted 23 September 2020 - 02:32 PM
Does it matter which way the SS camera is sitting in the bracket? I'm wondering if I can rotate it down so the tall part of the camera is facing down towards the scope.
#2 aa6ww
aa6ww
  • Loc: Sacramento, Calif.
Posted 23 September 2020 - 02:54 PM
I made a small bracket so I can mount my Starsense camera on my telescope dovetail bracket. Then flipped the camera around so its still in the same upright position as if it was sitting on top of my scope. Ive seen photos mounted upside down and they seem to still work fine since no one seems to be complaining.
This is my under my APM-152ED
....Ralph
Edited by aa6ww, 23 September 2020 - 02:54 PM.
#3 Mapkos13
Mapkos13
Posted 23 September 2020 - 05:59 PM
Thanks Ralph. The way you have it is essentially the camera setup I’m trying so it looks like it shouldn’t be a problem. It’s looks like it’s not dependent on camera orientation.
I’ll give it a go and if I get a bunch of erroneous readings I’ll know it may not work.
Thanks again
#4 audioengr
audioengr
Posted 23 September 2020 - 07:21 PM
High Point has a couple of ADM adapters for SS to dovetail bars.
  • Mapkos13 likes this
#5 stevety
stevety
  • Loc: San Ramon ca
Posted 23 September 2020 - 07:36 PM
I mounted my starsense under scope and did not change anything on camera and it works fine
#6 Woody218
Woody218
  • Loc: Bismarck, ND
Posted 24 September 2020 - 10:53 AM
Since the Starsense camera gets calibrated to the center of your telescope, it doesn't matter where on the scope it's mounted.
#7 Mapkos13
Mapkos13
Posted 24 September 2020 - 12:52 PM
HI all let me try to be a little more clear about my question. I’m not concerned where on the scope it’s mounted.
My question revolves around how the camera itself is oriented in its mount. Since you can rotate the camera 360 degrees in its mount, does it have to be setup a certain way or can I spin it in whatever direction I want it to be?
If you look at the SS camera, typically you always see the tall end of the camera pointing up. Can I rotate the camera so the tall end is pointing down or sideways for instance?
#8 Maritime
Maritime
Posted 24 September 2020 - 12:57 PM
Calibration is calibration is calibration.
Edited by Maritime, 24 September 2020 - 01:12 PM.
#9 Woody218
Woody218
  • Loc: Bismarck, ND
Posted 25 September 2020 - 07:56 AM
It doesn't matter if it's rotated in the mount...you can mount it rotated, upside down, however you want it positioned.
  • StealthPrelude likes this
