Which size filters? (31 or 36mm) for ASI294MM and is a focal reducer/flattener required for SCT?
1 reply to this topic
#1 ryanha
ryanha
Posted 23 September 2020 - 02:33 PM
I just put in an order for a ZWO ASI294MM with a Celestron OAG + ZWO174 guide camera.
(ngl, I'm a bit nauseous about how much $$ I just spent smile.gif)
Anyway, I will be putting this beautiful equipment on a Celestron SCT 8".
My question is:
1.) should I go for 31 or 36mm filters & filter wheel (planning on doing 7 position)
2.) Is a focal reducer/flattener required or can I go with this setup to start with?
FWIW, I think I will likely eventually one day get another telescope (shorter FL and faster optics) so ideally I get filters that will carry over if that makes a difference.
Thanks in advance!  And if you don't mind (even if you don't think it) tell me I made some good choices just now about spending this much money to get poor nights sleep smile.gif
--Ryan
Edited by ryanha, 23 September 2020 - 02:34 PM.
#2 glancey
glancey
  • Loc: Santa Ana, CA, USA
Posted 23 September 2020 - 02:55 PM
I have the ASI294 color that I use on a Celestron SCT 8. A focal reducer/flattener is a must-have for DSO imaging. I have both a Celestron .63 and a NightOwl .4. These reduce the imaging time by a significant factor. Hyperstar is another, more expensive option for fast imaging. The 294 works great for DSOs.
For planetary imaging, a barlow lens is needed to increase the focal ratio to match the 4.63um pixel size of the ASI294. A rough estimate of the correct ratio is 5 * pixel size. I have a Celestron 2.5X barlow that I use to acceptable effect for planetary imaging. I really should get either a 1.5X or 2X barlow for better imaging, or a camera with a smaller pixel size for planetary work.
Sorry I can't help you with the filters.
Edited by glancey, 23 September 2020 - 02:58 PM.
