Classic Celestron C5 balance weight
11 replies to this topic
#1 ANM
ANM
  • Loc: El Paso, Texas, USA, Earth, Sol system, Orion-Cygnus arm, Milkyway
Posted 25 September 2020 - 02:33 PM
A couple of months ago I bought a classic C5. I use the 1.25 visual back, an Orion 1.25 Dielectric mirror diagonal, and various Excell eyepieces and the C5 gets pretty tail-heavy. I have some Celestron weights with the little threaded stub sticking out and they work great on both a C90 Astro and a classic C8, but the C5 doesn't seem to have a threaded hole for that use. Am I missing something?
#2 WarmWeatherGuy
WarmWeatherGuy
  • Loc: Las Cruces, NM 32° N, 107° W
Posted 25 September 2020 - 03:14 PM
You can attach a counterweight to the dovetail. See these images.
#3 Kasmos
Kasmos
  • Loc: So Cal
Posted 25 September 2020 - 04:18 PM
IIRC, the C5 had a little square-ish 'C' clamp with threads that went on the edge of the cell for the weights.
Edited by Kasmos, 25 September 2020 - 04:19 PM.
  • Don W and ANM like this
#4 Kasmos
Kasmos
  • Loc: So Cal
Posted 25 September 2020 - 04:36 PM
  • ANM likes this
#5 Pete W
Pete W
  • Loc: Hutto, TX
Posted 25 September 2020 - 06:21 PM
Here's what the counterweight bracket thingy looks like - they can be hard to find:
And attached to the edge of the tube - there's a set screw in the hole:
Before I picked the bracket up I used a velcro band and a small weight  - this actually works better because it is adjustable by sliding the band up or down the tube. I found that the small screw-on weight a tad too light and the next larger one to be a tad too heavy.
  • ANM likes this
#6 ANM
ANM
Posted 25 September 2020 - 06:31 PM
Thanks for the response but the classic C5 is on the original C* fork mount so there is no dovetail. If I try to put a dovetail bar on the C5 I have the same problem, no holes that can be used to attach it.
I guess the clamps are the way to go or the velcro idea. On the clamps where is the set screw?
Edited by ANM, 25 September 2020 - 06:38 PM.
#7 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 25 September 2020 - 06:33 PM
My weights had a clip for the cell edge.
  • ANM likes this
#8 apfever
apfever
  • Loc: Colorado
Posted 25 September 2020 - 08:26 PM
There are TWO versions of this clamp.
The later C5 had a sand cast cell that was much thicker. This version had one of those clamps with a wide curved groove to fit on the cell.
The earlier C5 had a thin machined cell. That version of clamp had a much narrower curved groove.
The wide groove on the later clamp is sloppy on the thin early cell but can be shimmed.
The thin groove on the early clamp won't fit on the thick sand cell. Heads up.
The set screw is an allen type that is down inside the hole weights screw into.  The clamp is put on first, then the weights screw in over the set screw holding the camp to cell.
Edited by apfever, 26 September 2020 - 06:11 PM.
  • ANM likes this
#9 CHASLX200
CHASLX200
Posted 26 September 2020 - 07:42 AM
I thought the older C5's had the thinner black cell pre 1976 with the small round base and the big round base had the thicker cell. Not sure about the 90's made one arm deal C5.
  • Kasmos likes this
#10 davidmcgo
davidmcgo
  • Loc: San Diego, CA
Posted 26 September 2020 - 09:50 AM
Chas is correct. The early 1970s sand cast C5s had an anodized thin front cell with the same outer diameter as the tube.  The later die cast orange tubes went to the fatter cell.  There are two versions of the clips for the weights as apfever says, and a 3rd for the C90.  All as scarce as hens teeth.
Dave
Edited by davidmcgo, 26 September 2020 - 09:53 AM.
  • Kasmos likes this
#11 apfever
apfever
  • Loc: Colorado
Posted 26 September 2020 - 06:09 PM
Yes!  I am corrected, the early ones had the nicer machined cell, later ones regressed to the unmachined sand cast.  My bad. I corrected the entry.
  • ANM likes this
#12 ANM
ANM
Posted 27 September 2020 - 02:26 PM
Thanks! That I did not know...
