Tube rings not flush all the way around
Orion equipment
2 replies to this topic
#1 Astronomigo
Astronomigo
Posted 28 September 2020 - 07:37 PM
Just received an 8" f/5 from Orion, and there's a little bit of space between the rings and the tube in some places.
I will call the screws to close the rings at 3 o'clock.  At 3 and 9 o'clock things are flush, and at 6 and 12 things are not.
The maximum gap doesn't appear to be more than 1 mm.
I hesitate to tighten the rings much more because the tube already made a noise or two when I tightened the rings.
Is it normal for the rings not to be flush all the way around?
#2 Bean614
Bean614
  • Loc: Mass.
Posted 28 September 2020 - 08:29 PM
"Is it normal for the rings not to be flush all the way around"
Yes.
#3 SteveG
SteveG
  • Loc: Seattle, WA
Posted 29 September 2020 - 07:03 PM
Their rings are cast aluminum, somewhat crude. Provided they hold the tube securely, and you can loosen and rotate the tube as needed, you should be good.
Also tagged with one or more of these keywords: Orion, equipment
