Tube rings too tight
26 replies to this topic
#1 cpsTN
cpsTN
  • Loc: Rutherford Co, TN
Posted 30 September 2020 - 09:50 PM
Recently I purchased a 6in f/6 Newtonian OTA from Agena Astro. The tube rings are so incredibly tight that I cannot rotate the tube within them. In fact, when I set the tube into the rings, it sits on top with a noticeable gap (see photo). I contacted Agena and they said that this is the way the rings are supposed to be that you have to remove the tube in order to rotate it. I don't know why they would have it this way but they do. Is there anything I can do to remedy this or should I just buy other rings or just adjust to this situation? they would fit properly or do I just need to buy larger rings? The OTA diameter is about 172mm.
#2 Shorty Barlow
Shorty Barlow
  • Loc: Lloegyr
Posted 30 September 2020 - 10:08 PM
I have a 150mm, f/6 Newtonian. It's a TS Optics (GSO SVD series). Agena sell the same scope I believe but branded as GSO.
The rings on mine don't appear to be like yours, although the OTA isn't easy to rotate. Quite a few GSO Newtonians suffer from tight rings I believe.
Edited by Shorty Barlow, 30 September 2020 - 10:37 PM.
#3 Jon Isaacs
Posted 30 September 2020 - 10:18 PM
Charles:
That's not right. You should not have to remove the tube to rotate it.
Have you considered returning it?
How thick is the felt?
#4 EJN
EJN
  • Loc: Between eigenstates
Posted 30 September 2020 - 10:23 PM
I have the same scope, and the rings were tight too. Not like in the photo though.
I stripped off the felt, and put a single layer of blue masking tape lining the rings, and waxed the
tape. Now I can rotate the tube pretty easily.
On another thread, someone said they bent the rings slightly wider. However, being cast aluminum,
there is a thin line between bending and breaking.
#5 cpsTN
cpsTN
Posted 30 September 2020 - 10:27 PM
Charles:
The felt is No more than a millimetter, maybe two but I doubt it.
#6 cpsTN
cpsTN
Posted 30 September 2020 - 10:31 PM
Someone else mentioned doing that as well.  if it doesn't work, I'm going to have to buy other Rings anyway. They did offer me a full refund but then I'll have to find another scope and it doesn't make sense because I bought it specifically because it was a 6in that wasn't an f/5. Orion from where I got the amount, has a set of 178mm ID rings. I'm wondering if those will work without being too loose.
#7 Shorty Barlow
Shorty Barlow
  • Loc: Lloegyr
Posted 30 September 2020 - 10:42 PM
It may be you have the wrong rings for the OTA.
https://agenaastro.c...176mm-6-93.html
I don't know if these are for 150mm GSO Newtonians.
#8 cpsTN
cpsTN
Posted 30 September 2020 - 11:01 PM
Since you posted that, I emailed them and they have responded and I asked if I could exchange the rings that you mentioned for the Rings I have and they said that the Rings I have are the same ones that you mentioned. So I don't know what the hell's going on boss apparently the rings that they put on their Scopes are not supposed to be loose in any way shape or form. ???
  • Jon Isaacs likes this
#9 Sky Muse
Sky Muse
  • Loc: Mid-South, U.S.
Posted 30 September 2020 - 11:25 PM
Can you post a full view of the tube in relation to the rings, and from a farther distance away?
I have a "dreaded" 6" f/5 myself...
But that's a Synta product; no trouble with the rings, yet yours came with a much nicer, metal focusser.  Had I to do all over again, I probably would've gone with a 6" f/8 "Dobsonian", a Sky-Watcher; hindsight is indeed 20/20.
I've had very little trouble with tube-rings, and most of my telescopes are entry-level, beginner-grade.
#10 doug mc
doug mc
  • Loc: Tamborine Mountain Australia
Posted 30 September 2020 - 11:38 PM
I have a standard 6 inch Synta dob which i mount on an eq5. The Synta rings for this scope are 180mm internal diameter for this ota. A little larger than the GSO, but could be made to work.
#11 cpsTN
cpsTN
Posted 01 October 2020 - 02:07 AM
I'm currently at work (2am CT) so I don't have access to the scope right now. I will tomorrow morning and I will take wide shot photos of the whole thing. Whether I can post them or not I don't know since they live at you to 500k it's hard to get them that small but I'll see what I can do. They'll be on here I say 8 a.m. Central Time
#12 cpsTN
cpsTN
Posted 01 October 2020 - 02:10 AM
 I'm going to do a very accurate measure of the diameter by using the curcumference of the tube, then do similar work on the rings. Then I'll see what rings I need if anything.
#13 Sky Muse
Sky Muse
Posted 01 October 2020 - 03:11 AM
If your computer time is spent solely on a "smartphone", then I can see the difficulty.  I'm on a desktop, and I have a laptop as well.  Both have paint-programs that allow for re-sizing images.  I do not own a "smartphone" myself, as I came to despise telephones in general during my last employment.
#14 cpsTN
cpsTN
Posted 01 October 2020 - 09:01 AM
I have a conouter at home. I just dont at work.
#15 Shorty Barlow
Shorty Barlow
  • Loc: Lloegyr
Posted 01 October 2020 - 09:16 AM
I make mine 19cm external diameter and 17.5cm internal diameter.
I'm not including the felt lining.
Edited by Shorty Barlow, 01 October 2020 - 09:17 AM.
#16 cpsTN
cpsTN
Posted 01 October 2020 - 09:53 AM
I measured the tube circumference and did the math. I, then, outlined the rings and both measurrments were within half a millimeter of each other. No wonder they're so tight. Tube diameter comes out to 176.67mm. The Orion rings that are in stock have an inside diameter of 182mm, so those should work fine. I should be ordering them tomorrow.
Edited by cpsTN, 01 October 2020 - 09:59 AM.
#17 EJN
EJN
Posted 01 October 2020 - 10:28 AM
I have a set of those rings, from a Celestron Omni (Synta) 150mm f/5, they look the same as the Orion rings (but are painted white). The problem is they will not tighten on the GSO tube at all - I just tried it. They will need either thicker felt or another layer. My concern would be a thick layer of felt would compress over time and become loose.
I'm going to try putting on a layer of cork, then felt over the cork.
Edited by EJN, 01 October 2020 - 10:30 AM.
#18 LDW47
LDW47
  • Loc: North Bay,Ontario,Canada
Posted 01 October 2020 - 01:05 PM
Why don’t you give us a full pic of the scope sitting in the ringings to get the full perspective of the situation ? This partial doesn’t do it for me, kind of unbelievable at this point !
#19 LDW47
LDW47
Posted 01 October 2020 - 01:09 PM
Just keep monitoring it, if / when it compresses then address it, it won’t be a sudden compression, it will be gradual if at all. After the scope is seated properly and tightened down why would it compress much more ?
#20 Shorty Barlow
Shorty Barlow
  • Loc: Lloegyr
Posted 01 October 2020 - 02:02 PM
I hope it all works out.
#21 Bistromath
Bistromath
  • Loc: Central Minnesota, USA
Posted 01 October 2020 - 07:44 PM
Ed Ting mentions the issue with the rings on this scope in his YouTube video:  https://www.youtube....h?v=2owlm_8zaOc
The only solution he provides is to open both rings slightly to rotate the tube.  Not ideal.
Sorry that I can't offer any sage wisdom to resolve your issue.
  • Shorty Barlow likes this
#22 LDW47
LDW47
Posted 01 October 2020 - 08:07 PM
When I want to rotate my 6-7 refractors thats what I do, open them up very slightly, thats all it takes ! How can the scope fall out, it is still well secure in the rings !
#23 cpsTN
cpsTN
Posted 02 October 2020 - 03:20 AM
Open the race finally would be wouldn't be an issue but with this one most of the time you have to open the range completely and that nearly pick up the 222 row said it's against the tube rings are only Nathan a millimeter larger it seems so unless there's a dew everywhere, it's nearly impossible to turn.
#24 Shorty Barlow
Shorty Barlow
  • Loc: Lloegyr
Posted 02 October 2020 - 03:36 AM
Yeah, Ed's right, I do the same. He's right about the slight focusing issues as well. They're good scopes for the money though. Good mirrors.
#25 cpsTN
cpsTN
Posted 06 October 2020 - 03:37 AM
I ordered new rings.
