Powering Asiair Pro - Celestron Powertank Lithium LT?
5 replies to this topic
#1 adamsdp
adamsdp
Posted 01 October 2020 - 11:42 AM
I have an evolution mount and looking for a way to power an asiair pro and asi533  camera.  Woudl the Celestron Powertank Lithium LT be a good choice?  It looks small enough to strap on the leg of the tripod.
#2 GazingOli
GazingOli
  • Loc: Stuttgart GERMANY
Posted 01 October 2020 - 12:17 PM
you can strap it easily to the leg of a tripod. I am powering my CPC800 with it as you can see here:
I just do not know how long you will last with the tank. I am using it only for the CPC.
CS.Oli
Edited by GazingOli, 01 October 2020 - 12:19 PM.
#3 adamsdp
adamsdp
Posted 01 October 2020 - 12:54 PM
Thanks for  sending the picture.  I am only going to use it to power the Asiair Pro and asi533 camera and don't typically observe for more than 2 hours so thinking it will be enough.  It looks like the asi533 uses 22 watts of power while haven't seen definitive information on what the Asiair Pro uses.
#4 GazingOli
GazingOli
Posted 01 October 2020 - 01:11 PM
For two hours no problem as far a I concern.
However be aware that you will need a splitter cable because the power tank has got only one 12 V output. AND I never tried, but it is said that you can either use the 12 V OR the 5 V USB output, but not both at the same time. If you are interested I can test it. I just read it somewhere in one of the forum.
CS.Oli
  • adamsdp likes this
#5 adamsdp
adamsdp
Posted 04 October 2020 - 08:05 PM
Thank again for the information and I put one on order so can try it out as well.
#6 adamsdp
adamsdp
Posted 09 October 2020 - 09:43 AM
How are you dealing with cable management for you camera?  If I am going to strap the battery to the tripod leg and then power the Asiair Pro which is riding on the scope, I am thinking I will need a long power cable so when the scope slews, I won't run into problems.
