Observing with the Agema 130SD Apo
10 replies to this topic
#1 ullomat
ullomat
    Vendor (astroshop.eu)
  • Loc: Bavaria - Germany
Posted 08 October 2020 - 05:10 AM
Hi all,
since there is not much info about the Agema Optics Refractors, I wanted to share my experiences of the Agema 130SD Apo.
One info first, you may call it disclaimer: I work for astroshop.eu and the Agema 130SD is our presentator, which I loaned for testing some weeks ago. I will use it on for the Mars opposition and will put it back afterwards to our showroom.
This review is based on my personal opinion, though. As a long term visual observer and refractor fan (also a severe case of takitis smile.gif  ) I think and hope I can provide some useful information. And a comparison of the Agema, a TOA-130 and a FC-100DZ. But more on this later.
Mechanics
As to be expected of such a high end telescope, the mechanics, fits and finish are top notch. I have nothing to complain here. Expect the unusual finder scope holder, which is its own system. But this is no show stopper imho. The focuser is smooth and has no shifting or backlash. Works as expected and at Feather Touch level, at least for visual applications.
The retractable dew cap has no locking screws, but holds its position without problems.
The whole scope weights 10,5kg with rings and dovetail, plus mirror diagonal and a heavier eyepieces (Nagler 31) it is around 12kg. I used a iOptron CEM-60, which worked out fine, my own AZMount Pro was an edge case while focussing, but worked, too.
Optics
We did a bench test with our Agema 130SD samples at our astrohop workshop and none of the three scopes are below a strehl of 0,97, measured at 532nm green light. Our tester did not find any other pronounced optical flaws and stated the optics a high quality overall. I did not perform the testing myself but I have no reason to doubt these figures after observing with my sample of the 130SD.
As you may know, the Agema is a fluorite doublet refractor, the fluorite element is the inner one, which can be easily seen with the green laser test. The laser beam disappears, when it goes through the fluorite lens.
My own star testing (3mm DeLite - 0,38mm EP and 2,5mm Nagler T6 - 0,31mm EP) showed a very similar star pattern inside and outside focus. I could not detect astigmatism or spherical aberrations with my star testing skills.
The star (Vega and Atair) remained white in focus, a little inside and outside focus the diffraction rings showed a hue of color at these very high magnifications. A little hue more colour, than I see in my Tak FC-100DZ at this stars and exit pupils using the Delite and the Nagler. Since both scopes are f/8 this is comparable imho. At exit pupils down to 0,5mm I did not see any color, even outside focus.
For the record I used a Baader BBHS 2” mirror diagonal, not straight through observing. For practical observing, there is no doubt that this optic is up to the task. At this price point, this has to be imho.
Observing
My main targets are deep sky objects, but since Mars, Jupiter and Saturn are good to observe currently, I did some sessions at these objects, too. The Moon (which I usually avoid as a deep sky guy grin.gif ) also gave pleasant views of course.
The used eyepieces where : N31, Delos 17,3/10/8/6/4,5/3,5 Delite 3 and Nagler T6 2,5 and a Baader BBHS 2” mirror diagonal.
Star Clusters
Open clusters are perfect targets for such refractors. I am used too the view of my FC-100DZ and the presentation in contrast of the Agema 130SD was equal. Pinpoint stars from edge to edge and a dark and uniform background. The difference in resolution was obvious between the 100mm and the 130mm, a bit more than I expected. M13 could be resolved near to the center at 297x (Delos 3,5mm), the 100mm just resolves a third of the “way in” to the center.
The fainter M 71 showed its origin as a cluster best at 173x (Delos 6) with fine and different stars regarding brightness. One of my favorite clusters, NGC 7789 “the bowl of stars” in Cassiopeia, fits right in the FoV with the 31mm Nagler. A great view with the fine stars of the cluster and the pairs of brighter stars forming the bowl.
Double Stars
I observed the famous Albireo and epsilon Lyre. The colors of the two “Albireos” are very impressive in the 130mm and I could see no difference in the way of the colour presentation from the FC-100DZ. Epsilon Lyre was resolved (all four stars) with 130x (Delos 8) and showed a wide and black gap of the closer doubles at 231x (Delos 4,5).
I haven’t put the Agema to the limit at double stars, this is still on my list. If anyone has a hint which double would be a good challenge, please let me know.
Planets/Moon
At good seeing, the views of the Moon especially but also the planets remained sharp up to maximum magnifications at 346x (Delite 3mm). I tested the moon also with the 2,5mm Nagler at 416x but there was no gain of details any more, which is obvious. Jupiter showed nice details, so did Saturn. The latter is always more difficult to me since there is less contrast between the bands and colours.
Mars was really impressive. I never saw a better Mars in any scope so far. Dark structures, a nearly pure white polar cap and pale white cloud structures. This as in particular great when I used a binoviewer from a friend which gave a magnification of 208x.
Comparison Agema 130SD and TOA-130
I visited a telescope meeting three weeks ago, located at 1200m above sea level in the bavarian forest, germany. The sky is quite dark there and we had two clear nights. One had bad seeing and we had to stop our comparison at 200x. Not a challenge for both scopes. We set both scopes close to each other and used the same diagonal (Baader BBHS) and eyepieces (Delos) for the test. Since both of us had the same gear here, we did not even have to switch the eyepieces. We just put in the same focal length and changed just the observers. On this first night, there was no real difference between the TOA and the Agema. Except for my  impression, that the Agema had a bit more darker background than the TOA. Not much, but noticeable for me. The owner of the TOA was not sure at this. The second night, seeing was better and we tried to figure out and difference on Mars, but we did not find anything. Both scopes performed really well. As a further test, we compared both scope at daylight. The target was the top of a spruce tree, in particular some small shoots and needles. Including a tiny fly, which sat there for a while. At 297x (Agema) and 285x (TOA), again the 3,5mm Delos, we tried to figure out details which may be seen or seen not in the other scope. The results were quite equal again. I did favour the rendering of the details again in the Agema, as did another experienced observer. But there were also two votes for the TOA. To sum it up, we did not find a winner here, both are top notch telescopes.
Summary
My personal opinion about the Agema, the company did a really good job with this scope. Optics and mechanics are really good. The comparison to the TOA-130, which is a proven performer, shows no downside of the Agema. At least for visual observations. Since there are no photographic accessories like flatteners or reducers right now, this test has to wait.
I think if somebody wants to have a top notch visual refractor, the Agema 130SD should be on the list. As a fluorite doublet, I would prefer it to the TOA for visual applications. I just wish the whole scope a little bit lighter, but on the other hand side, the whole system is quite robust.
I hope I could give some useful information for all people interested in this line of scopes and if anybody has questions, please feel free to to contact me or write in this thread. I have the scope still here to do some observing or to measure things etc.
Clear skies,
Uli
Edited by ullomat, 08 October 2020 - 05:15 AM.
  • plyscope, Jeff B, Scott99 and 13 others like this
#2 25585
25585
Posted 08 October 2020 - 05:49 AM
An Agema 130mm seems a very desireable visual refractor. "Agemaitis"?
  • ullomat and sanbai like this
#3 Deadlake
Deadlake
Posted 08 October 2020 - 07:05 AM
When I saw the specifications for this scope the first thing I thought of was an FS 128 you can buy. Any idea of how this scope compares? I know its heavier due to the lens cells engineering, but any thing else. Also at this price range it's close to a TEC 140, any comparisons.
Main attraction of this scope is being a doublet, which should translate into better temperature acclimation then the competitor triplets around this price point.
Edited by Deadlake, 08 October 2020 - 03:09 PM.
  • ullomat and 25585 like this
#4 StarAlert
StarAlert
Posted 08 October 2020 - 01:14 PM
I have been considering an Agema for visual only. I have an ioptron AZ Mount pro, too. It sounds like the SD 120 may be a better fit.
  • ullomat likes this
#5 Scott99
Scott99
  • Loc: New England
Posted 08 October 2020 - 01:25 PM
Nice report!  In the USA we call this a "QC" or "quality check".  If you work in a restaurant and get a little bit hungry you do a "QC" on some of the food in the kitchen laugh.gif
NGC 7789 is a favorite of mine as well and is an excellent refractor object (bright OC's).  It's got a fancy name too...the "White Rose" or "Caroline's Rose" for Caroline Herschel.
I would expect this lens to exceed an FS128 based on the specs.  These Agema scopes and the Tak FC100DZ and DL seem to be new variations on the doublet apo design that completely eliminate false color.  At least in the visual wavelengths.  Astro-Physics did a couple scopes like this in the early 90's as well but they never went into large-scale production.
So the 130 is supposed to weigh 9.5kg?  about 20 pounds.  the 150 about 28 pounds.  That's similar to what current model AP scopes weigh, a little more than TEC.  For a long tube and focuser that can handle big cameras without flexure you're probably not getting much lighter than these.
Edited by Scott99, 08 October 2020 - 01:31 PM.
  • ullomat, gnowellsct and Tyson M like this
#6 gnowellsct
gnowellsct
Posted 08 October 2020 - 02:11 PM
I've been enjoying 7789 for decades and it is popular with fellow club members and friends.  It is lovely.
But it's not far from NGC 663 which is flanked by NGCs 659 and 654, I'm afraid it is vastly under-publicized due to the popularity of Carolyn and her Rose.  So let's call it Carolyn's bouquet...to help it get some more attention.
663/659/654 are due E of M103, about 1.7 degrees.  A fantastic five inch apo object.
Congratulations to OP on the new scope there has been quite a bit of interest in this company but the number of scopes in the field has remained limited so far.  Greg N
Edited by gnowellsct, 08 October 2020 - 02:12 PM.
  • ullomat and Tyson M like this
#7 Jeff Morgan
Jeff Morgan
  • Loc: Prescott, AZ
Posted 08 October 2020 - 06:01 PM
If they can hit their calculated polychromatic Strehl it will exceed the Zeiss APQ:
https://www.agemaopt...com/telescopes/
Although I am a bit concerned that my mount will handle the 150.
#8 Tyson M
Tyson M
  • Loc: Canada
Posted 08 October 2020 - 07:27 PM
Nice review of some premium scopes! Thanks for sharing.
The Achilles heel of the TOA is the cooldown and the weight.  With this Agema scope, you get about the same, or maybe slightly less weight. Similar length.
Cool down should be a tiny bit quicker....any analysis on that aspect or no?
#9 ullomat
ullomat
Posted 09 October 2020 - 05:39 AM
Hi all,
thanks for you comments. I will try to answer your questions.
- An Agema 130mm seems a very desireable visual refractor. "Agemaitis"?
I would rate this scope a desireable for visual, yes. Since I do no astrophotography, I cannot test or evaluate this. Agemaitis? Who knows... smile.gif
- I thought of was an FS 128 you can buy. Any idea of how this scope compares?
I could not test/compare the SD 130 to a FS-128 so I have no personal opinion on that. When I look at the specs, there should be an advantage for the SD 130, but this has to be verified
- I have an ioptron AZ Mount pro, too. It sounds like the SD 120 may be a better fit.
From my point of view, yes. The AZMount Pro works OK with the SD 130, but due to the lower weight and shorter tube of the SD 120, the combination would be more solid than the AZPro / SD 130 combo.
-In the USA we call this a "QC" or "quality check".  If you work in a restaurant and get a little bit hungry you do a "QC" on some of the food in the kitchen
- Cool down should be a tiny bit quicker....any analysis on that aspect or no?
Both scopes were out for two hours before we startet the test, to avoid any cooldown effects. But we did not check anything during the estimated cooldown period.
Clear skies,
Uli
  • Tyson M likes this
#10 StarAlert
StarAlert
Posted 09 October 2020 - 06:45 AM
Hi all,
Clear skies,
Uli
Uli, both tubes have a focal length of 1,040mm. The SD120 is 3.5 kg lighter, though. I don’t know. Perhaps the length is a bigger issue than the weight.
Edited by StarAlert, 09 October 2020 - 07:14 AM.
#11 ullomat
ullomat
Posted 09 October 2020 - 06:52 AM
You are absolutely right. I just checked the specs, sorry for the mistake. The 3,5kg less will help for the stability but the lever is more or less the same as for the SD 130. So a test would be good to check out the "real world" differences  but we have no SD 120 in stock unfortunately.
cs,
Uli
Uli, both tubes have a focal length of 1,040mm. The SD120 is 3.5k lighter, though. I don’t know. Perhaps the length is a bigger issue than the weight.
